 Post subject: Bug in ST 3.40
PostPosted: Wed Dec 10, 2008 2:23 pm
I've experienced this on two different machines.
Load a preset, like FM Transmitter.
Now, tick or untick anything -- and watch
the settings change on the multi-band.
To duplicate again .. reload a preset.
Cheers!
 Post subject: Re: Bug in ST 3.40
PostPosted: Wed Dec 10, 2008 4:00 pm
Ah! That's caused by rounding errors (for example, a slider is set to 0.0012. Then when something is ticked, all the sliders are read back from the GUI, and the returned value is - for example - 0.00119. Which is then displayed as 0.0011.
I guess I should re-read all the numbers immediately after choosing a preset to fix (hide) this.
