PostPosted: Sun May 15, 2022 8:11 am
Hi all,
How do I make the bottom window go full scale? It was fine until I started playing.
See pic attached.
https://imgur.com/a/rWTPjEP
Cheers,
Baldrick
PostPosted: Sun May 15, 2022 2:41 pm
Configuration main window > Uncheck "Draw Scopes at Half Height"
PostPosted: Mon May 16, 2022 12:54 am
Awesome, did the trick. Thank you!
