PostPosted: Mon Mar 21, 2022 6:02 pm
Marian has recently updated their Seraph sound cards. By default, they now have a slightly flatter frequency response, but that comes at a cost in phase response. When testing the new cards we found that we got up to 10% overshoots in our MPX signal.
We have contacted Marian about this and they have created a new driver that has a setting to get the old/normal behavior back. So, if you have an MKII card, please perform the following steps:
  • Install the latest driver version, v4.3.4.0
  • Go to Settings -> DAC, and choose "Linear Phase, Slow Roll-Off"
  • Make sure to press Apply to confirm your selection, otherwise it will be lost after a reboot.
We will add a setting in Stereo Tool soon to make the response completely flat (with these settings you loose about 0.3 dB at 57 kHz, similar to what the MKI cards had - since we know that the filter is phase linear we can easily compensate for it, so look out for a "Seraph MKII" checkbox in the near future).
PostPosted: Sat Apr 02, 2022 2:57 am
Hans you remember the MPX Passthrough thing? Do you think you can make it pass a complete 192khz signal into the FM Output? The calibration from the FM Output section is outstanding with my realtek soundcard.
Need Help? Call me, I can help you have a better sound with your actual audio processor, Analog? Unknown Brand? No Problem At All!
PostPosted: Tue Dec 17, 2024 5:57 pm
Is this also the case with the (new) Clara soundcards? I've recently bought a Marian Clara B soundcard and am planning to install it soon.
Do I also need to set DAC to "Linear Phase, Slow Roll-Off"? And is the setting you mentioned already in ST l? I haven't really checked yet.
PostPosted: Wed Dec 18, 2024 12:18 am
Marian has updated their driver default settings after we told them about this, so this isn't necessary anymore! At least not if you buy a new card and (only) use the latest driver version.
ST setting isn't there yet, and we're planning to check the Clara card soon.
