Post new topic  Reply to topic  [ 193 posts ]  Go to page Previous 14 5 6 7 820 Next
PostPosted: Wed Jan 05, 2022 10:29 pm
No mono bass? why not disable whole Multipath part for HD, since it's for FM only.
PostPosted: Wed Jan 05, 2022 11:18 pm
BETA015 is posted. It doesn't yet solve this last issue (which also wasn't new) but everything else that was reported in this thread should be fixed now.
I have problem with web interface. Buttons are not working at all and no meters like eq graph and vu. Browser FF last or edge(chrome).
At the /modern/ page falling into infinity loading.
But nobody posted about it so what do i wrong ?
x86
Weird. I see here that *drawing* the EQ in the old web interface fails. But aside from that everything works, in both the old one and in /modern/ (in your screenshot it's not even visible).
Which exact version of Stereo Tool are you using?
Can you press F12 in the browser, then go to Console, and show what it says there (mainly if there are any errors, they would be displayed in red).
Im using beta015 x86.
Here errors from js console:
Uncaught SyntaxError: "" string literal contains an unescaped line break objects.js:1445:1523
Uncaught TypeError: widget is undefined  thimeo.js:337:21
PostPosted: Thu Jan 06, 2022 12:07 am
x86
Ah! That must be some weird character that's apparently not encoded correctly. Can you check what line 1445 of objects.js is?
PostPosted: Thu Jan 06, 2022 12:08 am
Not sure what you mean? Mono Bass is there now for streaming out as well. Disabling Multipath for non-FM is a good one indeed.
PostPosted: Thu Jan 06, 2022 12:14 am
AddString(9041,false,true,["RDS PS text","PS text","PS",""],["2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\","2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\","2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\",""],true,false,"2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\\",8192);
PostPosted: Thu Jan 06, 2022 12:45 am
Both multipath and Mono bass does not work for HD in beta015.
PostPosted: Thu Jan 06, 2022 12:48 am
But let's please keep mono bass for streaming/hd, it's a nice feature, especially for headphone wearing.
Three Decades of Country!
PostPosted: Thu Jan 06, 2022 12:50 am
There are now 2 Mono Bass settings, one for Multipath (which works for FM) and one for streaming.
PostPosted: Thu Jan 06, 2022 12:56 am
Found it. There are a LOT of \'s in that line. They all are encoded in this file as \\, which takes twice as much space - and that space wasn't available. Solved by giving it enough space. (For those who want to know: The number of \'s after truncation was odd, so the last \ was interpreted combined with the closing " which was therefore no longer treated as a closing quote.)
PostPosted: Thu Jan 06, 2022 12:57 am
Yup, it's there, but you'll have to enable it manually if you upgrade from an older version of Stereo Tool. I can make that automatic.. Not sure how much sense that makes because I think most people don't want to make the bass mono for streaming, even if they do for FM. (?)
