PostPosted: Sun Nov 21, 2021 6:06 am
What is the low quality % you can run at to help with cpu load and still have good audio quality from Stereo Tool.
I am currently I am running at 96% should I run it at 92%??
that depends on what you use ST for and whether your current PC can handle it.
if you use it for AM broadcast, 50% is good, for FM broadcast, 75% is good, for personal listening on your sound system or for mastering, 100% is good, theres really no need to go above 100%.
PostPosted: Sun Nov 21, 2021 8:05 pm
I'm curious how the "Latency" size is affected by the CPU "Audio Quality" slider. 150% on 1024 sounds a lot better than 100% at 1024. And 100% at 4096 is better than that. I guess what I want to know is: what Quality should one use for a Latency of 2048 and what difference does it make? I mostly use 1024/150% for gaming or 4096/100% for media consumption (plugin version). I notice the difference most in the sub-bass accuracy.
I assume everybody who uses ST for broadcasting would use the largest size available since lag isn't as much of an issue as it is for playing games, right?
PostPosted: Mon Nov 22, 2021 5:36 pm
on my laptop (Clevo P870DM2_DM3) i operate with 2048 samples at 100% quality at 30mS latency on "normal output" reliably.
PostPosted: Tue Nov 23, 2021 4:02 pm
Is the audio quality still really good??
yes. for 2048 samples, it is, but i would not drop it any less than 2048 samples.
mainly, lower frequencies are affected more prominently by lower samples and can be observed on the display scope by using a sinewave tone 60Hz and lower, in some cases, you can hear this distortion as well.
