PostPosted: Wed Nov 17, 2021 11:43 am
Hi. I'm trying to use the FM Sound Card output without any extra broadcast processing (32 bit VST in this case) to pipe my audio to a mixer in the other room. Is it possible to do this without enabling AM or FM Transmitters? If not, I'd like to wish for this capability.
I realize I can enable the AM Transmitter and disable all the checkboxes to get a (mostly?) unaltered signal. Is this the intended way to do what I'm attempting?
My issue with this is that sometimes the AM Transmitter breaks all audio processing, and I don't know what triggers it. I just know disabling it fixes it, but adjusting the CPU cores (and buffer etc...) don't appear to solve this. The only way I've found to get processing back is to disable the AM Transmitter, which stops pushing audio to the selected and enabled FM Sound Card.
Thanks!
PostPosted: Mon Nov 22, 2021 5:47 pm
i,m using AM evry day and night 24 hours never brake all audio processing..... :shock: .
