PostPosted: Fri Sep 17, 2021 4:37 am
When I use WinAmp or MediaMonkey with ST to play Videos, the audio is delayed by what seems like up to 350 milliseconds. Is there a way to delay the video to sync with the audio?
I know that VLC Media player has a built in feature to adjust the Video in 1ms increments up to (I believe) a second, but VLC does not support Stereo Tool, and that's unfortunate.
A software means of delaying the video would be ideal. Maybe another AV player program that supports ST and can delay the video?
Thanks!
TechnoMonster
PostPosted: Fri Sep 17, 2021 6:21 am
I believe you can use OBS Studio to do this by loading up Stereo Tool as a filter for your audio source and Render Delay as a filter for the video source. There are many guides out there on how to use OBS and set up video/audio sources and how you would view the projection in fullscreen or window.
https://obsproject.com/
PostPosted: Thu Sep 30, 2021 12:27 pm
You can quite easily delay the video in VLC and set it to any number you want using the combo box at runtime, so it immediately takes effect.
PostPosted: Sun Oct 03, 2021 1:14 pm
The question was for alternatives to VLC.
You can use the 32 bit version of "MPC-HC BE" in conjunction with the audio version of "FFDShow" and the Winamp DSP version of Stereo Tool. I just played around with this to see if it worked, and I was able to make it work on movies and music. And I didn't notice any delay creeping in, so it might already compensate for that stuff as well. Regardless there's a timing offset in the MPC-HC-BE playback software if further adjustment is necessary.
PostPosted: Tue Oct 05, 2021 10:27 am
Why don't you use the standalone version of ST and feed audio via virtual cables? Then VLC is back in the race again :-)
