PostPosted: Tue May 25, 2021 2:29 pm
I've been pulling my hair out for the last few hours trying to get this to work looking all over the internet and cant seem to find anything that works simply haha. The closest I think i can get is with
radio = mksafe(pipe(data_length=0, replay_delay=1.5, restart_on_error = true, process='//var/azuracast/stereo_tool/stereo_tool - - -s /sts_files/Kuesound.sts -q -k "<xxxxxxx>"',radio))
BUUT it only returns the following error from Liquidsoap.
2021/05/25 20:45:20 [threads:2] Queue generic queue #1 crashed with exception Broken pipe in write()
Raised at file "tools/process_handler.ml", line 296, characters 16-23
Called from file "duppy.ml", line 151, characters 61-77
Called from file "duppy.ml", line 279, characters 14-23
Called from file "duppy.ml", line 313, characters 7-24
Called from file "duppy.ml", line 356, characters 5-9
Called from file "tools/tutils.ml", line 225, characters 18-54
Does anyone have Stereo tool running with Liquidsoap in Azuracast in a docker? That was a mouthful.... Any and all help would be awesome! Thanks guys!
PostPosted: Fri Sep 03, 2021 10:17 pm
See viewtopic.php?f=2&t=30688 for example !
PostPosted: Mon Sep 06, 2021 7:18 pm
The example only works for live audio input. If "mksafe (input.http (url))" is used as input, it unfortunately does not work.
This error message:
20/09/09 13:05:26 [http_4677: 3] Buffer overrun: Dropping 0.00s. Consider increasing the max buffer size!
...and there is only silence.
