PostPosted: Sun Apr 04, 2021 7:34 am
I'm looking to turn the FM stereo generator on/off externally. (The idea is, my automation should be able to call a script to disable the stereo generator just prior to airing long-form mono programming, then enable it again once said programming has finished airing.)
Seems to me this might be possible via the web interface. I was hoping to see that it could be done via a simple HTTP GET or POST request, but everything seems to be done in JavaScript, a language in which I'm not fluent.
I gather there's some sort of XML-based exchange happening between Stereo Tool and the web-based GUI, but so far have been unable to figure out how it works.
Anybody done something similar to this before? If so, any suggestions?
--Keith
PostPosted: Mon Apr 05, 2021 10:50 am
Keith, you can do it with this command:
http://[YOUR_ST_IP_ADDRESS_HERE]:8080/json-1/update{"113":{"new_value":"0"}}
Where values are
0 = Encode Stereo NO
1 = Encode Stereo YES
BR,
Janne
