PostPosted: Mon Mar 29, 2021 10:58 pm
Note in the image that the AutoEQ meters show action that exceeds the Max boost for the top three bands. Why does the boost exceed the Max boost setting?
Great Hits and More!
http://RadioDAVE.US
PostPosted: Mon Mar 29, 2021 11:52 pm
None of them are over +6dB
Only 3rd from bottom is +4.5 and it's set to 3.
PostPosted: Tue Mar 30, 2021 12:42 am
Three bands are exceeding the "Max boost" settings - not sure why.
11k band: The "Max boost" is set to zero, but is being boosted by 1.5 dB
6k band: The "Max boost" is set to +1.0 dB, but is being boosted by 2.5 dB
3k band: The "Max boost" is set to +3.0 dB, but is being boosted by 4.5 dB
http://RadioDAVE.US
PostPosted: Tue Mar 30, 2021 3:15 am
haha.. by "top" 3 bands i was thinking on top bands on picture.
Anyway it's all relative i suppose. Best would be to measure them. I noticed same long time ago. I don't use that filter but i might measure them sometimes.
PostPosted: Wed Apr 21, 2021 11:08 am
There is some relative behavior in this, so those values are 'soft' limits. This is expected behavior...
