Post new topic  Reply to topic  [ 40 posts ]  Go to page Previous 1 2 3 4
 Post subject: Re: Stereo Tool 9.60
PostPosted: Wed Nov 18, 2020 1:01 pm
I've put the AGC Per band display error in the todo list.
The other thing ("2 (3 requires ...") is not a bug, but I thing we do need to change how this works. In short: If you load a preset that has 4 AGC bands (which is a paid option, part of Advanced Dynamics) and then press the "Turn all unlicensed features off" button, we had to do something that doesn't completely mutilate the preset. So instead of going to 2 bands we're using a setting with memory. And there's no way to hide that in the current GUI. Anyway, instead of this I think what we need is a checkbox that temporarily turns all unlicensed features off, which you can turn off to get back to the normal mode. (And in the upcoming new GUI we probably want to do that per feature).
PostPosted: Wed Nov 18, 2020 4:15 pm
it would be useful for an asterisk to appear on the preset or change color when changing a parameter ... voluntarily [or] unintentionally.
I concur. An asterisk on the title bar or preset field would be handy and when attempting to design one. There's not currently an easy way to compare and contrast presets other than A/B ing.
The idea of coloring a setting that's been affected is indeed interesting.
I guess nobody ever noticed... but settings that have been modified have 2 white dots on the right side.
in 10 years of using the ST, I had never noticed those two dots ... sorry.
however, I think it is a useful thing that the change should occur on the preset name, or color change or a distinctive sign that catches the eye ... sorry if I insist.
PostPosted: Wed Nov 18, 2020 4:59 pm
Oh wow, I feel so unobservant :o
I did notice those dots, but I didn't make the connection that that's what it was signifying. :oops:
Let me guess.... you thought it was a display bug? :)
Yes, but I didn't look into reproducing it or anything like that. It's subtle enough to ignore it almost entirely, and I knew a new GUI was on the way, so I never posted anything.
šŸ¤
edit: Would it be reasonable to add a copy of the Deep Bass Synthesis quick adjust somewhere on the main page of the Bass Effects?
PostPosted: Thu Nov 19, 2020 8:43 pm
I've noticed that channel linking in new AGC doesn't work.
3rd channel (highs) occasionally drops too much and not follows the 2nd (mids).
PostPosted: Fri Nov 20, 2020 9:01 am
There is no such link, you can currently only link the bass band to the band above...
PostPosted: Sat Nov 21, 2020 7:58 pm
Hm, what about this?
PostPosted: Sun Nov 22, 2020 12:00 am
Ah, that's between left and right. Within a band.
PostPosted: Mon Nov 23, 2020 6:16 pm
Thnx for explanation. Hate to question again, but is there a way, that AGC bands are linked together?
On 3rd band (6,5 KHz) I managed to "trick" to follow the mids because of band slope, but that is not what I would like.
PostPosted: Mon Nov 23, 2020 6:19 pm
Not yet, but it makes sense to make something like that. Also to add something to have "go to levels" when gating per band as in MB1. So that's planned.
PostPosted: Mon Nov 23, 2020 6:37 pm
Why Matrix is not same in Legacy and Current AGC?
