PostPosted: Mon Jan 24, 2011 6:57 pm
Please,
I really enjoy the sound I get from the "FM Transmitter Europe (Soft Stereo)" preset but, I'm not sure if the preset is kept as a default when I close and then re-start Winamp. Is there a way to configure this preset as default ?
I would like to configure the plug-in and run it on a hidden window so none can change it, but I want to be sure that the selected preset is stored.
Thanks in advance.
PostPosted: Mon Jan 24, 2011 11:30 pm
Welcome Ucat,
unless something is wrong, Stereo Tool should always start up with the settings that were active when it was closed. So you shouldn't need to do anything. (The NAME of the preset is no longer displayed though!).
PostPosted: Sat Jan 29, 2011 12:29 pm
Welcome Ucat,
confirm, when closed the "stereo tool", start always with default setting!
are many years that I use this tool,and to be honest the latest version no i like ! i still the version 5.02 with this version "5.02" in fm working very well.
I always work with (hard compression/Pop/rock)
