 Post subject: Sound blaster z
PostPosted: Fri Aug 07, 2020 7:33 pm
Hello!!
I am looking to buy a sound card for fm broadcasting. I am using an ESI juli@ right now, but looking for a backup solution. I found this one: https://us.creative.com/p/sound-blaster/sound-blaster-z
Has anybody used this? Does RDS work?
My second option is a Behringer umc202hd, but I prefer an internal card instead.
Thanks!!
 Post subject: Re: Sound blaster z
PostPosted: Tue Aug 11, 2020 3:26 am
Rule #1 for soundcards: Never use Creative Sound Blaster soundcards. Anything else is a better bet. It will work, but analog output is usually very bad.
PostPosted: Wed Aug 12, 2020 4:36 am
Pay attention to Bojcha,
Go for the Behringer...
https://fmfeeling.com
PostPosted: Wed Sep 09, 2020 1:00 pm
What will be the best soundcard to recoed and process audion under 100?
PostPosted: Mon Apr 26, 2021 8:30 pm
For me this is really only true if you leave their "enhancements" active. I mean, they offer direct passthrough on Z SE for example with ASIO. So it's bit perfect, even if it's analog.
Lose all the enhancements for gaming and it sounds decent. Does it match Behringer or DANTE/REDnet? No. Is it okay for broadcast? yeah.
