PostPosted: Thu Jun 11, 2020 10:01 pm
The 3 preset i will provide are intended for those trying to acheive the loud "optimod" sounds that made lots of radio stations popular, or sort of close. This preset processes audio to ensure a very constant and loud audio without over equalising the audio. This preset is based on my classical presets elsware on the forums with some changes to the preset to make it sound like one of the "loud" presets included in the digital OPTIMOD processors.
First preset is FLAT, ideal for mastering, Second is FM, obviously for limiting high frequencys as preemphasis is used and the third preset is STREAM, same as flat but a single band limiter takes place of the final clipper to ensure no clipping occurs as this could mess the codec and waste bandwidth
Thank U Very Much i like this sound Number 2 / Optimod FM high for indonesian genre music its good , i will be back for two days with report i hope this preset stable for multi genre in my country .. thanks for work .. very apreciate thats.
EDIT : 12 Hour iam running with this preset 95% stable for multi genre in my little station FM , make me happy , thank u very much :D
https://www.viagrasansordonnancefr.com/ ... fizer-inc/
