PostPosted: Sun Jan 16, 2011 10:19 am
This settings are cosmetic edit for 5.02 settings and are specially for FM Broadcasting with NON-compressed! but strong limited balanced sound to obtain maximum allowed deviation .Settings tested with MPXTool and NO artifacts and other kind of sound distortion.
Use for Only! FM broadcast . Enjoy !!!
Recommended to use with HI Quality sound sources ( 320KBit MP3 , FLAC , AIFF... ect. ) and You will find the power .
As You probably know select your 192KHz sound card and adjust ONLY your soundcard Master Volume from Soundcard Panel , Don`t touch the StereoTool Sliders because the ratio between the Sound/Pilot tone/RDS signal will be LOST !
File comment: You Will Remember It :)
DJ-DOGGY V2 ST 6.00.rar [2.54 KiB]
Downloaded 911 times
