 Post subject: Linux Stream Input
PostPosted: Sat Apr 11, 2020 6:06 pm
We are just evaluating Stereo Tool and want to input our Web Stream into stereo tool before broadcasting. Is it possible to do this on Linux like you can on Windows?
Thanks
Pete.
 Post subject: Re: Linux Stream Input
PostPosted: Sat Oct 10, 2020 8:56 am
This has my interest as well!
PostPosted: Thu Oct 22, 2020 8:21 pm
You have your stream already as an icecast stream? You should avoid that, better feed a clean, uncompressed signal to ST.
Anyway, you can use the jack version of ST and use whatever source you have and feed it into ST.
Then it's just a matter of patching the sources to ST.
