PostPosted: Wed Apr 01, 2020 7:31 pm
Hi all,
I want to record the Normal Output into Reaper and, at the same time, I want to send the MPX into a transmitter. I've accomplished that, but...
I'm noticing that the Normal Output receives the MPX signal even when the FM Ouput is off and the FM Transmitter section is ON.
The Normal/Stream Signal is set to the de-emphasized version of the FM Output, even though the emphasis shrill is there.
All this might sound a bit... lot... confusing...
Another "issue" found... The Low Latency Output buffer cycles tremendously, even with the same buffer settings of the Normal Output, wich is stable.
Win10, UMC404HD, AMD FX8350.
Am I doing something wrong?
