 Post subject: 9.40 some GUI errors
PostPosted: Sat Mar 21, 2020 6:07 pm
Hello,
Long time ago i`m not participant for anything. But i now saw some things. x86 standalone.
Look at the pictures
Error 1 : "Current AGC" : There is no space between "AGC" and "Stereo" monitor windows like others have.
Compatability thing is a little messy.
Error 2: it`s all clear, again little messy.
Error1
https://ibb.co/VTg8frz
Error2
https://ibb.co/Qf1WKGh
Sorry, i cannot upload them here(big size). They are 269kB and 199 kB...
 Post subject: Re: 9.40 some GUI errors
PostPosted: Mon Mar 23, 2020 4:10 pm
I would like to add that in the Web Interface, when choosing a preset, the one above the one you select is actually loaded.
PostPosted: Tue Mar 24, 2020 5:39 pm
@DJ-DOGGY, 1st problem not fixed (I can't find what's wrong, and we'll get a new GUI soon anyway). 2nd problem is solved, that setting should have been hidden in Digital mode.
MrKlorox: I don't see it here, can you check in the native GUI what it's showing there? It seems to work fine here, I've tried multiple categories.
PostPosted: Tue Mar 24, 2020 9:15 pm
WebGUI bug confirmed here too.
Running ST on a Mac and remote from a Mac with Chrome.
Select presets from "Recent Preset Files" and it selects the preset above the one you select. From the buildt-in presets it selects as expected.
Regards,
MrDonT
PostPosted: Tue Mar 24, 2020 11:17 pm
Upon further inspection, it seems to only happen in the Recent category, and only in the web interface. As you can see from the snippet, if I want to choose "ty-mic2," I'd have to click "tv-tbvoice," which is then reflected as "ty-mic2" in the native GUI. This happens in both the 32-bit Windows VST and Stand-alone versions.
I only found this because I was doing some A-B tests. Perhaps this does not go here, but in the new GUI, it would be awesome to be able to undo (no not THAT "Undo" ;) ) your last processing change. I'm just talking about typical CTRL+Z stuff. Even if a history is too much to keep, a simple toggle between the current and most recent change would be greatly appreciated. Or Better yet, one undo/history per module. For preset authors, it would be a multiple click saver to not have to save/load a preset/module every time you changed something, and wanted to check back.
PostPosted: Wed Mar 25, 2020 6:44 am
Hans, may be it`s a resolution dependant
Try set to 1280x1024 or 1024x768 and see if the problem is there.
PostPosted: Thu Mar 26, 2020 3:51 pm
I think Hans meant that he's having trouble finding the code that causes that visual inconsistency. And he's not going to look at fixing it in the current graphics code since a new graphical user interface is being created. This is my interpretation.
PostPosted: Fri Mar 27, 2020 12:24 am
Yes, indeed. I tried fixing it and nothing worked, then I gave up on it instead of spending more time on it...
PostPosted: Mon Mar 30, 2020 10:47 am
i noticed another thing; when having the bass EQ on 2 band the xovers are in the bass band.
setting it to 3 or 4 band and applying default crosses gives no longer bass bands only... xovers are devided over whole spectrum...
