PostPosted: Tue Mar 17, 2020 11:53 pm
[EDIT] This preset has been rebuilt. It requires Advanced Clipper, Declipper, Advanced Dynamics licenses to sound correct. It also makes use of the 4-band AGC and BIYF Booster found in release 9.61.
It retains a bass focus. I use it for metal as well as hip-hop. If you like any setting in this preset, feel free to use it for your own. I'm sure there are values in this preset that I don't know where they came from. Many are set relative to each other via the golden ratio (phi).
Stereo Tool release version 9.61
ty-0255.sts [167.79 KiB]
Downloaded 460 times
ty-0249.sts [167.78 KiB]
Downloaded 413 times
older
ty-0234.sts [167.47 KiB]
Downloaded 439 times
PostPosted: Tue Jul 07, 2020 3:23 pm
I finally got a good headphone amp, and you're right. :oops: Version 38P sounds BAD.
[EDIT] I've redesigned this preset. Please give it another try. It's louder and denser than it was with the option to easily reduce that effect.
