PostPosted: Wed Dec 04, 2019 6:36 am
I am using the file polling solution here, and my question is: is it possible to change somehow the file polling interval? Sometimes it takes too much time to response. Thanks!
PostPosted: Thu Dec 05, 2019 10:09 am
Hi, it *should* look at that file 4 times per second. Note that the text won't be actually updated until the full sequence has been transmitted, so you should put the changing parts of the text in the beginning!
PostPosted: Thu Dec 05, 2019 9:36 pm
Something is definitely wrong here, or I missing up something.
Even trying with only one character containing in the text file it takes at least 2 seconds to see the change. But sometimes it is more than 15 seconds. (Not just in the receiver but at Stereo Tool RDS page too...)
Edit:
It helps a bit when starting 1s: before \r"C:\a.txt"
This step reduces the response time to 1 - 5 seconds. Weird.
