Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
 Post subject: Re: PhoneBooster
PostPosted: Mon Mar 29, 2021 10:27 pm
It's available on the download page. And has been for a while...
https://www.stereotool.com/download/pho ... taller.exe
PostPosted: Mon Mar 29, 2021 10:32 pm
Sorry Hans, still not working. When I run it, nothing happens (even with admin rights)..
PostPosted: Fri Sep 17, 2021 5:45 pm
Requests:
- Ability for the application to open and process sound files directly. At least support WAV.
- VST2 or VST3 version of PhoneBooster.
- Incorporation of PhoneBooster into StereoTool.
- 64 bit versions.
PostPosted: Tue Mar 22, 2022 11:53 pm
Ditto on the request for a VST plugin.
We record regular mic + caller into Adobe.
*If* it can be made to recognize the caller portion and run this as a post processing effect, it would be invaluable.
PostPosted: Wed Aug 17, 2022 11:46 pm
I try install PhoneBooster and get infinity crash loop after select "Neutral full processing".
PostPosted: Wed Aug 24, 2022 11:26 am
Whoops. Cause found and fixed, the next beta build (probably 992-046) should work again.
PostPosted: Wed Jun 21, 2023 8:09 pm
Hans,
How hard would it be to make a VST plugin for this?
I have one single piece of audio I would like to process from a file.
It's a DJ drop someone uses, it's about 4 seconds
PostPosted: Mon Sep 04, 2023 7:55 pm
Please tell me if this is wrong to say, but I have a feeling this is completely doable from within the trial mode of the standalone version. You'll need to route it through a DAW, but I bet there's a 4-second gap between registration reminders you can use.
