 Post subject: Findings
PostPosted: Thu Oct 14, 2010 4:32 am
Hi
Just thought I'd mention this, we used an old XP sp3 machine for NORMAL audio processing with ST.. I don't think its onboard soundcard supports 192khz even thought ST says otherwise in its current output samplerate (yes I know it can't be accurately detected)
I used a tugicom TX180s TX, tried both a car stereo and a normal indoor receiver.. both picked up stereo pilot but the stereo signal has a high freq squealing sound that can be mildly heard through the TX (when switched to mono). I also tried RDS but I doubt either receiver supports it. :(
The TX itself has a stereo coder so this could be partly the reason for the squealing, or it could be the dodgy onboard soundcard.. In either case it was just a test for curiosity since I have never used ST's transmitter feature.
 Post subject: Re: Findings
PostPosted: Thu Oct 14, 2010 2:10 pm
Hi Russell
What is the sound chip on motherboard?
Did you try "Calibrate FM Transmitter"? - Try "Calibrate the FM stereo pilot tone".
PostPosted: Thu Oct 14, 2010 11:37 pm
Its a Foxconn/Winfast 760GXK8MC with an ADI 1888 codec
If this chart is anything to go by: http://www.hardwaresecrets.com/printpag ... -Table/520 <- this machine doesn't support 192khz
I haven't tried the fm calibration in ST, I think you need test equipment for that (?)
PostPosted: Thu Oct 14, 2010 11:39 pm
Well as you see it's only up to 96kHz so nothing to do with FM.
PostPosted: Fri Oct 15, 2010 1:07 am
If it's just for home use, and you want stereo, here's a trick:
Go to the FM Transmitter window, then at the bottom right click on 'FM Transmitter Calibration". Enable it, and select 'Similar, but only using 23-38 kHz stereo signal'.
This gives a NON-STANDARD stereo signal, which might contain really big spikes (composite limiter won't work here) - but it should sound good if you don't push the volume too loud.
PostPosted: Fri Oct 15, 2010 3:47 am
It was more out of curiosity and testing for later on.
But thats a cool "hack" (?) with the stereo system, are there any more tricks you know of? I'm interested to hear :)
