 Post subject: Old agc
PostPosted: Fri Aug 23, 2019 4:50 am
Quick question.
How can I get the old bass agc back on newer versions?
I know I can install an older version, turn bass agc on and then upgrade to the latest.
Is there a way to get this setting back, without going through the above.?
Before anyone tells me it has been discontinued, I like it as a very easy way of balancing the bass.
David.
 Post subject: Re: Old agc
PostPosted: Fri Aug 23, 2019 8:01 am
You probably just need to enable "deprecated settings" ;)
PostPosted: Sun Aug 25, 2019 8:29 pm
Thanks, I will give this a try on my other machine.
I like the "OLD" bass agc,because it is a nice easy slider, that I can fine tune with for the deepest of bass.
I play really modern and really old recordings at moderate volume. I can fine tune the bass much easier with this old feature.
David.
PostPosted: Fri Aug 30, 2019 4:44 pm
Deprecated settings didn't work, but thanks.
PostPosted: Sat Aug 31, 2019 2:35 pm
Open Stereo Tool then go to the configuration tab. You want to change the operating mode to either advanced or expert, check off show deprecated settings. Then go to the AGC tab and it should be there.
PostPosted: Mon Sep 02, 2019 10:53 am
Enable "Deprecated Settings" and go to AGC. Then select AGC type "Legacy AGC". Then Bass AGC appears.
PostPosted: Thu Sep 19, 2019 6:43 pm
I can confirm that this works, thanks for the fix!
