I googled and have found some information (most german) for Mac users.
But nothing for Windows.
So here is my
Vuvuzela Filter V1:
<?xml version="1.0" encoding="UTF-8"?>
<Equalizer PatchFormat="1" GlobalGain="-3.6">
<Band Frequency="235.147505" Gain="-22.7628866" Bandwidth="0.25" Mode="Peak/Dip"/>
<Band Frequency="468.892005" Gain="-24" Bandwidth="0.25" Mode="Peak/Dip"/>
<Band Frequency="337.553868" Gain="5.93814433" Bandwidth="0.67" Mode="Peak/Dip"/>
<Band Frequency="934.986372" Gain="-24" Bandwidth="0.25" Mode="Peak/Dip"/>
<Band Frequency="651.332228" Gain="6.18556701" Bandwidth="0.63" Mode="Peak/Dip"/>
<Band Frequency="1834.00809" Gain="-24" Bandwidth="0.25" Mode="Peak/Dip"/>
<Band Frequency="1342.17144" Gain="6.68041237" Bandwidth="0.5" Mode="Peak/Dip"/>
<Band Frequency="2233.77327" Gain="4.45360825" Bandwidth="1.89996863"
Mode="Peak/Dip"/>
<Band Frequency="20000" Gain="4.34226804" Bandwidth="1.89996863" Mode="Peak/Dip"/>
<Band Frequency="6607.65302" Gain="2.11546392" Bandwidth="1.89996863"
Mode="Peak/Dip"/>
</Equalizer>
You need this free VST-plugin
easyQ:
http://www.rs-met.com/freebies.html
If you need it as Winamp DSP use this free VST to Winamp DSP wrapper:
http://www.savioursofsoul.de/Christian/programs/winamp/
It's called
VST Host (it exists another plugin with same name, but this is something else), this one is better known as
Winamp VST Bridge.
I still prefer version 1.0 (because it pops up automatically at every start).
Higher versions are hidden until you press the config button.
Install
FFdshow (you need the Audio Decoder/Postprocessor) !
Then select
FFdshow Audio Decoder for MP2 and AC3 decoding inside your DVB software options/preferences.
Inside
FFdshow Audio Decoder configuration go to "
Winamp 2" and select
VST Host as DSP.
Then load
easyQ VST-plugin into
VST Host,
And finally load my
Vuvuzela Filter V1 preset for
easyQ.
Like with all how-to-do-it guides it is not as complicated as it seems to be (when you read this guide).
Of course you could use something else.
For example the trial of this green oscilloscope live thing in bypassed mode (I just cannot remember its name) as a global DSP host for the wrapped VST-plugin
and Stereo Tool !
Sorry, Hans I was not sure in which sub-forum I should post this topic.
So please redirect it, if necessary (or edit/remove the green oscilloscope tip) !
This filtering is not perfect.
I had only a few minutes at the end of the game
Portugal vs. Ivory Coast.
So, please tweak the settings and upload your own superior easyQ Vuvuzela preset here !
