Post new topic  Reply to topic  [ 166 posts ]  Go to page Previous 113 14 15 16 17 Next
PostPosted: Mon Jul 08, 2019 2:31 pm
Anything to do with Very High CPU usage from GUI?
No, but does that actually cause problems? I know it's a bit annoying when you move the window, but the old issue (white bars in the window) was way more annoying. I have thought of a workaround but I still need to implement t.
I didn't notice problems with that. With this now, whenever i log into PC and move window.. sound drops. Sometimes it even need few seconds to recover when remote. And yes, GUI stutters on any PC/Windows.. wich is visually lame.
PostPosted: Tue Jul 09, 2019 11:22 pm
I'm on holiday now, but I added a quick fix for it just before I left. I haven't fully tested it yet (mainly because on my normal pc I never get those white bars). But the new version is uploaded as 935-BETA001, so you can check it if you want. I'll be back next week...
PostPosted: Tue Jul 09, 2019 11:35 pm
Have a nice holiday Hans, you have earned it. :mrgreen:
PostPosted: Wed Jul 10, 2019 1:41 am
Yes, beta001 is ok.
PostPosted: Thu Jul 11, 2019 2:33 am
There's a bug in the latests Stereotool versions. When "Also Lows" (Compostite Clipping) is enabled (FM 75uS) the sound like underwater, specially in mono. See Bojcha's StarGate FM preset... In 9.35 beta 001 the bug persists.
PostPosted: Thu Jul 11, 2019 12:19 pm
Where can i download 9.35 beta 001 :?:
Thanks
PostPosted: Thu Jul 11, 2019 3:48 pm
Thanks
Swap the new version into the URL:
https://www.stereotool.com/download/stereo_tool_standalone_installer_64_BETA932-024.exe
becomes:
https://www.stereotool.com/download/stereo_tool_standalone_installer_64_BETA935-001.exe
Hot Country Hits!
PostPosted: Thu Jul 11, 2019 3:56 pm
Hi Tim,
Thanks a lot.
Regards
PostPosted: Thu Jul 11, 2019 3:57 pm
Hi Tim,
Thanks a lot.
Regards
You're welcome, wav. That works with all the different versions, or at least should, so long as Hans has a version uploaded.
Hot Country Hits!
PostPosted: Thu Jul 11, 2019 4:35 pm
Hi Tim,
Thanks a lot.
Regards
Ok noted.
