Post new topic  Reply to topic  [ 168 posts ]  Go to page Previous 111 12 13 14 1517 Next
PostPosted: Tue Jul 02, 2019 2:37 pm
Hoi Hans,
Als soundcard geeft asio mijn realtek aan bij beide versies.
Ik gebruik windows 10 home (up to date)
Ik ontdekte net wel dat als ik FM output selecteer terwijl normal output (die ik normaal gesproken alleen gebruik) ook aanstaat, ik wel ineens output geluid heb.
Als ik Stereotool dan opnieuw opstart is het geluid weer weg en krijg ik een melding dat FM output geen geluidkaart ziet.
Martin
PostPosted: Tue Jul 02, 2019 7:25 pm
Ah! I managed to reproduce the sound card issue here now. Great. From this point on it should be easy. :)
PostPosted: Tue Jul 02, 2019 7:35 pm
And that's also only with 9.32? 9.31 was ok?
Yes Hans only with version 9.32
PostPosted: Tue Jul 02, 2019 7:41 pm
Great!
I’ll wait for the new release :D
PostPosted: Tue Jul 02, 2019 8:59 pm
I just downloaded 9.32 from the downloads page on stereotool.com/download/ (Windows 64 bit). There's a bug in the release. When I start Stereo Tool, I don't get any audio, until I turn off ASIO and then turn it on again!
When I turn off ASIO, I hear the audio fading in. Then I turn ASIO on again and everything seems to work fine. I think the fading mechanism has a small bug which causes the ASIO to having to be restarted before any audio is let through
PostPosted: Tue Jul 02, 2019 10:01 pm
Also the 'Optimize audio for lossy compression' function also effects the FM output! Attenuate highs on stream has no effect on FM :-)
PostPosted: Wed Jul 03, 2019 12:21 pm
Again, can we have AGC Gate that reacts to signal after AGC ?
PostPosted: Wed Jul 03, 2019 3:36 pm
ASIO issue is fixed, uploaded and released as 9.33.
PostPosted: Wed Jul 03, 2019 6:28 pm
Perfect Hans, everything works fine now.
Martin
PostPosted: Wed Jul 03, 2019 11:14 pm
Not quite.
Had major problems and went back to 9.22 64-bit
