PostPosted: Mon Jun 07, 2010 1:32 am
Ok not a whole year but feels like it :D
The output is controlled by win7's audio mixer which pushes it up to 96 khz, I don't think that should degrade the audio, but its not adding anything either just makes my receiver run in Stereo instead of "Dolby-Prologic" without me having to change it every time. (im lazy :roll: )
My audio controller is an ALC888, and my surround receiver is a Panasonic SA-HT40. The only difference is I have two cabinets with each having an outward facing 150 watt sub-woofer, and inward facing 80 watt woofer. The rest of the speakers are stock, and they are fine for my tastes and budget. :D
File comment: :D
Gtxx_06_10.zip [2.22 KiB]
Downloaded 1154 times
PostPosted: Tue Jun 15, 2010 11:14 pm
Small edits and ST 5.01 :)
[Common]
Pre amplifier=2
Post amplifier=1
Extra loudness=1.029999971
Extra loudness - Allow extra highs (advanced)=2500
Extra loudness - Punchy=0.284999967
Extra loudness - Max Punch peak=1.529999971
Extra loudness - Deep bass protection - Value=0.952250004
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=120.719993591
Bass protection - Deep bass boost=56.449996948
Bass protection - Raise clip level if highs get above=139.63999939
Bass protection - Maximum clip level raise=27.010000229
Hard limit output=1
[Noise Gate]
Enabled=0
Difference=0
Noise level=0.479999989
Relative noise gate level - Band 1=0.639344215
Relative noise gate level - Band 4=1.127659559
Relative noise gate level - Band 5=1.127659559
Relative noise gate level - Band 6=1.247190952
Relative noise gate level - Band 7=1.409638405
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=2
Attack speed=0.000031768
Decay speed=0.005328756
Above Top Limiter=0
[Pre Compressor]
Enabled=0
Difference=0
Delay enabled=0
Remove remaining loud peaks=0
Maximum volume - Band 1=76270
Attack speed - Band 1=0.001422295
Decay speed - Band 1=0.2147412
Dual band=1
Relative expected volume of highs=0.799999952
Relative maximum volume of highs=4.019999981
Remove remaining peaks above (relative to maximum volume)=2
Attack speed - Band 3=0.000005
Decay speed - Band 3=0.00025
Third band=0
Relative maximum volume of very highs=0.330000013
Enable smoothing=0
Smoothing time=10
Gating level=0
Use ITU-BS.1770=0
Channel separation=0.300000012
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=10000
Maximum volume - Band 0=10000
Maximum volume - Band 1=10000
Maximum volume - Band 2=10000
Maximum volume - Band 3=10000
Maximum volume - Band 4=10000
Maximum volume - Band 5=10000
Maximum volume - Band 6=10000
Maximum volume - Band 7=10000
Maximum volume - Band 8=10000
Attack speeds linked=0
Attack speed - Band -1=0.000015691
Attack speed - Band 0=0.000015691
Attack speed - Band 1=0.000015691
Attack speed - Band 2=0.000015691
Attack speed - Band 3=0.000015691
Attack speed - Band 4=0.000015691
Attack speed - Band 5=0.000015691
Attack speed - Band 6=0.000072158
Attack speed - Band 7=0.000132422
Attack speed - Band 8=0.000015691
Decay speeds linked=1
Decay speed - Band -1=0.005829701
Decay speed - Band 0=0.005829701
Decay speed - Band 1=0.005829701
Decay speed - Band 2=0.005829701
Decay speed - Band 3=0.005829701
Decay speed - Band 4=0.005829701
Decay speed - Band 5=0.005829701
Decay speed - Band 6=0.005829701
Decay speed - Band 7=0.005829701
Decay speed - Band 8=0.005829701
Above Top Limiter=0
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=1.247190952
Relative clip position - Band 0=1.247190952
Relative clip position - Band 1=1.247190952
Relative clip position - Band 2=1.247190952
Relative clip position - Band 3=1.247190952
Relative clip position - Band 4=1.247190952
Relative clip position - Band 5=1.247190952
Relative clip position - Band 6=2.278688431
Relative clip position - Band 7=2.278688431
Relative clip position - Band 8=2.278688431
Final limiter value=1
Final limiter decay speed=0.999000013
Final limiter clipping=1
Equalizer enabled=1
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1.020201921
Equalizer position - Band 4=1.040816307
Equalizer position - Band 5=1.061855555
Equalizer position - Band 6=1.105262995
Equalizer position - Band 7=1.127659559
Equalizer position - Band 8=1.127659559
[Stereo]
Enabled=3
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=1
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=41
AZIMUTH change speed=0.209999993
Image phase amplifier=1
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=10
Stereo Boost maximum amplification=2
Stereo Boost multiplier=1
[Channel Delay]
Enabled=1
Left Delay=0.0000008
[Output Filter]
Enabled=0
Lowpass filter=18660
Highpass filter=5
[Bass Boost]
Enabled=1
Strength=0.494300008
Start lowpass frequency of input filter=80
End lowpass frequency of input filter=180
Start lowpass frequency of output filter=180
End lowpass frequency of output filter=280
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=240
Start speed=3080
Number of rotations=7.329999924
Smoothness=0.919999957
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=0.949999988
Pre-limiter enabled=1
Pre-limiter relative volume=1.5
Reduced CPU processing=0
[FM Transmitter]
Enabled=1
Pre-emphasize=0
Pre-emphasis time=50
Output is pre-emphasized=0
Stereo encoder enabled=0
RDS encoder enabled=0
Pilot signal volume=18
RDS signal volume=9
FM overdrive volume=1.200000048
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/|\W"PLAYING %artist% - %title%        "/1s:\T2h\:\T02m\:\T02s/1s:\T2h\:\T02m\.\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=%artist% - %title% - %album%
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=0
RDS Artificial Head=0
RDS Compressed=0
RDS Dynamic PTY=0
RDS RadioText Enabled=0
RDS ClockTime Enabled=0
MPX Oversampling mode=Never
FM Transmitter Calibration - Phase shift 20 Hz=0.25
FM Transmitter Calibration - Phase shift 160 Hz=0.25
[Direct soundcard access]
Enabled
PostPosted: Fri Jul 16, 2010 10:31 am
very nice sound Thanks ! :P excellent
PostPosted: Wed Dec 08, 2010 1:14 am
Gtxx:
1. Nice preset!
2. Can I add it to Stereo Tool? If so, does it have a name? (Except 6_10 which is not very clear...)
PostPosted: Wed Dec 08, 2010 7:24 am
Yes of course dude! :D That's awesome! How about Gtxx's Dubstep Party. That's the kind of music I made this for, so makes sense? :|
If you have a better name, use it! :D
