PostPosted: Fri May 03, 2019 11:40 pm
In testing with MARIAN TRACE ALPHA, on windows 10 pro, with the same settings as JULI @ XTE, it just looks different!
With TRACE ALPHA, the audio input gets too high having to go down to -0.5 db, otherwise the audio sometimes fragments even using a machine with CORE i5 7400 with 8GB of RAM and 120GB SDS.
Note that the audio is very sharp and the quality is not the same using the same settings only by changing the board to JULI @ XTE, where the sound is very good! Besides not fragmenting!
Acquire TRACE ALPHA for being the top for the Stereo tool even the difference being small, but I would use it than the JULI @ XTE, I need help!
Follow the pictures of the settings used!
OSB: IF THE CONFIGURATION IS DIFFERENT FROM THIS, THE AUDIO IS PICTING !!! MAJORLY CHANGE THE ASIO BUFFER OF THE OWN PLATE! I REPEAT IF I CHANGE TO THE 24-BIT 2-CHANNEL AND 192,000 KHZ FORMAT THE STEREO TOOL GIVES HANGUN ERROR !! I HAVE TO RETURN TO 16 BITS 2 CHANNELS 192,000 KHZ.
OBS: Last installed driver!
I wish someone could help me!
https://ibb.co/G5bk992
https://ibb.co/z2ZnR1Q
https://ibb.co/Lzc0Zsd
https://ibb.co/mvBGN6s
https://ibb.co/s11nZHn
https://ibb.co/ZgtVt2p
https://ibb.co/JKbqBv2
https://ibb.co/4ZDpYQP
https://ibb.co/nBSdD8r
https://ibb.co/P5gkw4y
https://ibb.co/9WR3Rcx
https://ibb.co/ch3xvG3
