PostPosted: Mon Feb 11, 2019 9:53 am
After upgrading to the latest version of Stereo Tool (and foolishly not saving my settings beforehand), I've started having the Stereo Tool VST plug-in mute the first second or so of audio tracks when processed.
I'm confident it's some setting I haven't put back properly, perhaps having to do with the clearing of the buffer or not clearing or... something?
Can someone point me in the right direction? I can add a second of silence to each file before processing but it's a nuisance and frankly, I forget until I listen and realize I'm missing the first note.
Thanks!!!
Gene Savage
BlackLight Radio
https://BlackLightRadio.com
Tulsa, Oklahoma USA
PostPosted: Wed Feb 20, 2019 5:05 pm
It might be this:
Configuration -> Plug-in -> Winamp bug fix: Clean buffer at start of new track. Turn that off :)
It's on by default in the Winamp plugin only, but you might have loaded a preset that was created with the Winamp plugin, maybe?
I guess it's about time to make off the default here, this is an ancient setting - Winamp always played a pause between tracks and after that pause, the remaining audio in the buffer would get played. (Actually this shouldn't cause the start of a new track to be silent... But it's probably a good idea to turn this off by default, as hardly anyone uses Winamp anymore).
PostPosted: Thu Feb 21, 2019 6:16 am
I wondered about what you're describing, too, until I looked at my current settings:
https://ibb.co/fr7xhg3
It looks like the setting is already off.
Here's what happens to the first second of the file. I trimmed the silence so the audio started immediately, and you can see the first .275 of the second is silent.
https://ibb.co/hFvWH1g
Something else really odd about the window since I upgraded: the window is WAY too big for the contents, and I always have to resize the window just to get to the "OK"
Here's how it opens:
https://ibb.co/qDnDZDF
Here I've drug it over a little so you can see where it ends; you still can't quite see the bottom because of the taskbar...
https://ibb.co/1rWgQ7T
Did I somehow get a corrupted copy? Should I try downloading it again? Is there someplace I can go to clear all the settings and maybe get it back to the defaults?
Thanks for your help!
Gene Savage
BlackLight Radio
Tulsa, Oklahoma USA
