Post new topic  Reply to topic  [ 19 posts ]  Go to page Previous 1 2
PostPosted: Sat Jan 19, 2019 12:58 am
BETA009 is available! The new clipper highs protection settings are now enabled by default, and I've removed the separate number of steps and composite checkboxes (instead, there's an extra mode in the selection box; the 5 stagses didn't have any noticeable effect on CPU load so I just removed the setting.)
I'm planning a release build this weekend.
Hi Hans
My STS config file was running fine on v9.2.1
I updated to Beta009 today (been away and have missed prior ones) and it has come back as being unlicensed (all options)?
Never had that happen to me before - has anyone else seen this?
EDIT: Loaded the rego info again fine with no issues...
Ross
PostPosted: Sat Jan 19, 2019 3:19 pm
Many thanks for the new version! I've looked at it now, and the new improvements in Advanced Clipper are really outstanding. I don't mind you releasing it this weekend!
PostPosted: Sat Jan 19, 2019 4:53 pm
just a challenge: could you record your stereo tool build process and make it into a video then put it up on youtube
it would be fun to see it compile, was also wondering what build-env are you using (g++ on linux, VS, etx)
PostPosted: Sat Jan 19, 2019 7:40 pm
It is very much not.
PostPosted: Sat Jan 19, 2019 9:32 pm
I've made it very silent so it only prints when it starts with something or when it ends, or when a warning or error occurs. So, you'ld basically be watching a few DOS boxes which print a few lines of text per hour.
PostPosted: Sun Jan 20, 2019 5:41 am
Stereo Tool 64 Bit Standalone, adjusting Release Time in MB1..
Clicked OK and continued fine.
Ross
PostPosted: Sun Jan 20, 2019 9:59 am
Ross
Hm.... I didn't keep the 009 code (I only added presets since), but with the new code I can't find this spot anymore (the addresses changed way too much). I've release version 9.22 this morning. I'm not going to roll back, since this is code that I haven't even touched, so it's most likely something that has been here for ages.
If you see it again in the released version, please let me know, I can find what it is then.
PostPosted: Sun Jan 20, 2019 10:01 am
Version 9.22 release:
viewtopic.php?f=14&t=25799
PostPosted: Tue Jan 22, 2019 1:22 pm
:cry:
well what Dev env are you using? Visual Studio and MSVC as compiler or something linux like gcc and atom or something as editor
