 Post subject: Stream Encoder
PostPosted: Sat Jan 05, 2019 4:22 pm
Hello,
I miss an option to stream directly to an internetstream from stereotool.
Handy perhaps for the future maybe ?
Kind regards,
Marv
 Post subject: Re: Stream Encoder
PostPosted: Sat Jan 05, 2019 7:02 pm
In the Normal Output section (I/O->Soundcards) you can select Stream (via VLC) instead of an actual audio hardware and use the command line below to create the stream.
PostPosted: Thu Jan 31, 2019 12:01 am
It's on our todo list, we have someone who's working on a whole new I/O framework, this should be part of that. Might take a while though.
