Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: Stereo Tool 9.02
PostPosted: Mon Jul 23, 2018 4:30 pm
Stereo Tool 9.02 is available!
These are the changes since 9.01:
  • Delossifier: Detection of false positives reduced.
  • Multiband compressors: Added multiband clippers.
  • Sound card and MicroMPX packet speed correction: Improved and simplified. More robust and most constant.
  • RDS: MagicRDS support: Supporting hex numbers for AFCH=.
  • RDS via UECP: Added EON (Enhanced Other Networks) support.
  • RDS via UECP: Added Slow Labeling Groups support.
  • RDS via UECP: Added support for ODA (TMC traffic information, paging etc).
  • RDS via UECP: Added support for IH (InHouse) groups.
  • RDS via UECP: Added support for EWS (Emergency Warning System). Code is not yet validated!
  • GUI: Input level meter could flash.
  • GUI: Output scope ran too slow and could lag behind in certain situations.
  • GUI: Added support for displaying MicroMPX encoder errors.
  • GUI: Added (not found) to missing sound card in menu (for example when loading a preset from someone else).
  • GUI: Add clear error message if sound card that doesn't exist in the system is selected.
  • GUI: Increase VST window size to 1500x843.
  • Sound cards: Added 30-60000 Hz and 10-80000 Hz sweep tones for testing.
  • Bug fix: GUI mouse move priority was too high in stand alone version, could cause hiccups on slow 1 or 2-core systems.
  • Bug fix: Mac VST plugin didn't work.
  • Bug fix: Fixed NAN logging error.
  • Bug fix: With all meters running, was reaching the maximum number of meters allocated.
  • Updated and added presets.
  • MicroMPX SST/Stereo Tool integration: Only allowed "Ignore high frequencies" value is now 19200.
  • MicroMPX SST/Stereo Tool integration: Encoder did not get activated with FM output running in ASIO mode at 44/48 kHz. Works now, but FM output plays silence.
  • MicroMPX: Added stream password protection.
Note: MicroMPX is not yet included because we need a bit more feedback before releasing the new version and the integration in Stereo Tool. Soon though! If you want to use it anyway, you can make it available by creating a file "MicroMPX.unlock" in the directory from which you run Stereo Tool.
 Post subject: Re: Stereo Tool 9.02
PostPosted: Mon Jul 23, 2018 4:38 pm
When clicking any link on the official download site I get an error message that it can't save the file because the source isn't readable and it says that the server admin should be contacted. Entering the link directly downloads just fine.
EDIT: Bug in NoScript 10.1.8.8, fixed in 10.1.8.9.
PostPosted: Mon Jul 23, 2018 4:47 pm
Which link? They all work fine here...
PostPosted: Mon Jul 23, 2018 5:07 pm
Works fine here
Garbage in is Garbage out !
