 Post subject: Radio Fairground Sound
PostPosted: Tue Jan 16, 2018 7:59 pm
Hello @ll,
i change on my station www.radiofairground.de to Stereotool. Long time I had Optimod 8200 or 8400 On Air, but anyway, Stereotool sounds much cleaner and FM Clipping isn't good for Webstream. I know.
My Focus on this Preset was: Stay Clean, Loud, remove the highly compressed Sound of new songs... But don't loose the "warm body" on the Bass and have a good balance at all. Last thing handle the Auto EQ very very well. Nice tool!
Here's a first result, maybe you find something that could be better. I will share my Preset also in "Share youre Stereotool settings".
Link to listen
http://rs18.stream24.net/radio-fairground.mp3
Thanks!
PostPosted: Tue Feb 06, 2018 8:26 am
Thanks a lot! You can find it in the Share your Settings Departement
