Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 759 posts ]  Go to page Previous 170 71 72 73 7476 Next
PostPosted: Mon Jun 11, 2018 11:58 am
Windows 10 - Stereotool Standalone 64 bit.
Issue: Sliding Quality (CPU load) in CPU & Latency from 100% to lowest figure (20%?) causes crash.
Stereotool recovers the first time however repeating it more than once, one gets what appears to be audio corruption (delayed, distorted audio).
Rossco
PostPosted: Mon Jun 11, 2018 4:47 pm
Rossco
So you can reproduce this? I've tried it here and so far I can't. The crash is inside the Stokkemask filter, maybe you have different settings than what I'm testing with? Could you send me your *full* settings in a PM with which you see this behavior?
By the way, this code hasn't changed in over a year. Do you know if this is new?
PostPosted: Mon Jun 11, 2018 6:37 pm
My personal PC with Windows7 died after 7 years unrecoverable.
Now i am on Win10. and my StereoTool GUI flashing white color time to time, and always when i switch to different part of gui. Super Anoying :(
PostPosted: Mon Jun 11, 2018 8:50 pm
Flashing white color??? Only thing that sometimes happens is that not everything is updated when the window has been hidden - but it should never do that if you're switching between different parts of the gui.
PostPosted: Mon Jun 11, 2018 11:25 pm
Strange, tested on a Windows 10 build 1803 x64,i dont see flashing GUI
Garbage in is Garbage out !
PostPosted: Mon Jun 11, 2018 11:27 pm
I use Windows 10 here too and I don't see a flashing GUI problem, but I am using the Winamp Plugin.
I just use ST Winamp to listen to music.
PostPosted: Tue Jun 12, 2018 3:40 am
I think it's not problem in GUI.. i also have new Vega56 and drivers are so strange.
PostPosted: Tue Jun 12, 2018 10:07 am
Ok. Do you also see weird things in other programs?
PostPosted: Tue Jun 12, 2018 10:09 am
Stereo Tool 9.00 BETA089
Windows stand alone: https://www.stereotool.com/download/ste ... 00-089.exe
Winamp DSP: https://www.stereotool.com/download/dsp ... 00-089.exe
VST: http://www.stereotool.com/download/vst_ ... 00-089.dll
VST: https://www.stereotool.com/download/vst ... 00-089.dll
- Wait for Paul Thompson's fixed Breaking Dreams preset
- Fix Dale Sharp preset loading error
- Quick Adjust -> Bass Boost renamed to Basstardizer and works on both now (whichever is enabled)
- Output meter blinks red / clipped signal doesn't look tight enough. -> Ah, in "Ignore high frequencies" mode - make it less sensitive if that's enabled. -> Changed warning threshold from 0.5% to 2% in this mode, that seems to be enough so far.
- Add AM presets - check 8.55 directory
- Removed a few older presets
OLDER CHANGES:
- Fixed overshoots when using "Multipath Stereo Phase Difference Remover".
- NAN in clipper fixed
- Figure out default value for legacy clipper mode
- Add legacy bass clipper warning
- Updated Mousse and Breaking Dreams presets
- Fix new presets BS412 levels
- Put new presets in streaming section and find good levels
- Maybe add "Limit normal output" to main screen? Might be overkill given the detail of the other settings... -> No.
- Put Advanced Clipper on main screen?
- Remainder of Matt's todo list
- Improve VST load time
- Resizing VST plugin? - Hacked something in that APPEARS to work (tested in Reaper which supports resizing, and, Audition and VST_Scanner which don't). It IS a bit tricky (might fail under certain very weird circumstances, so feedback needed...)
- SST internal display is broken
- Check __restrict performance
- Bass clipper & Bass effects were not loaded/saved correctly when selecting to load/save those
- Put bass clipper etc on main screen
- Change Bass Clipper default values
- Reorganize and update Processing main screen
- Matt's todo list Partially done
- Fix "Hear" behavior when moving filters around (among others what Bojcha reported)
- Added some presets
- Optimized scope data collection code (less CPU expected, but more memory) To be tested in release mode, in debug it helps
- "Compensate steepness for band distances" default setting changed.
- Fix before clipper bass clipper in R128 mode.
- Windows command line build fails (Winsock2)
- WatchCat build fails (ALWAYS_SOUNDCARD_ACCESS not defined in global.h 44)
- Make sure that all the bass settings are saved correctly - Done, fixed some others as well (naming and some pages weren't linked to a save command)
- Update translations
- Fix Normal Output limiter behavior (phasing sound), must have been broken forever!
- Fixed broken 4000-6000 Hz behavior in ABDP in clipper - not sure when it broken, code got corrupted (I probably hit ENTER when a value was selected in the editor...)
- Put old bass clipper meter directly below sliders again to visualize the link between them.
- Clean up warnings
- Put in 2.1 dB threshold slider (TEST). YOU PROBABLY DON'T WANT THIS VALUE TO BE LOWER but it's there now for testing.
- Move bass clipper to a logical spot.
- Combine bass effects in GUI
- Dynamically move Equalizer and Bass EQ in left menu
- Find reported crash
- Optimize "Extra softness" code
- Basstardizer did not work for Quality > 100%
- Basstardizer start level is wrong, it start with a huge boost of the bass. - was caused by a missing initialization.
- Moved Bass EQ before True Bass if it's set before MB 1 (between it was already in that order, and it doesn't make sense to have different orders.
- Cleaned up warnings (partially done)
- Bass Clipper: Allow higher than 2 extra softness. - Done, and divided numbers by 2 - so 1.0 equals what was 2 before!!!
- 2nd bass clipper causes weird harmonics. Harmonics are probably boosted. Boost threshold (figure out by how much) and filter out harmonics. => Fixed, waiting for feedback
- Rivendell plugin build. 64 bit works, 32 not yet.
- Array met frequenties versus levels (dus de uitkomst van Fourier) resultaten naar buiten brengen
- Frequency array support other than 33 bands
- Support PTYN via ASCII
- GUI: Bottom meter section now reflects changes in processing order (for bass filters).
- Sjoerd's presets sound bad on some systems (i7-2xxx) -> Probably a rounding error (log(1) != 0). Waiting for feedback.
- Reduce new bass clipper 1st harmonic -> Added new "Soft mode" setting. 0 is same as previous beta, 1 and 2 are increasingly soft (allowing overshoots).
- BETA074 Pre-bass-clipper level was wrong (removed too much deep bass!), fixed.
- Legacy AGC & LLB levels slightly different from version 8.54 => Was accidentally partially using Symmetry mode. This has been broken since BETA036.
- Auto EQ legacy mode startup behavior broken
- Natural Dynamics levels are slightly different from version 8.54 (might not be a problem) -> No
- Add a pre-bass clipper without configuration in the main clipper, to avoid suffocating mid-bass. This protects the (old) bass clipper even if you don't enable the new one, it also reduces IMD in the mid/highs further!
- Bass clipper should do something with clipper drive. -> Not anymore if pre-bass clipper works
- NAN reported in basstardizer - MAYBE fixed, waiting for feedback
- Find optimal # steps for pre-bass clipper - 2 if Fisherman's Friend mode works well. Waiting for feedback!
- Bass clipper: Added "Reduce valleys" mode that reduces overreaction (keeps more deep bass and causes less harmonics)
- Start of song AGC etc behavior. Added starting point setting for AGC
- Renamed Hans/Matt mode to a more logical name in Bass EQ; changed display of number of bands to match what makes sense to users.
- Latest beta doesn't run on XP SP 2 (GetLogicalProcessorInfo can't be located in KERNEL32.dll). Question posted. => Too hard to figure out where it's coming from (and that wouldn't even necessarily mean being able to fix it).... I guess almost nobody will still be using XP SP2 anyway...
- Quality > 100% Bypass switching causes buffer filling to move -> Tested, not (or no longer?) true
- SJP in AGC reported to be broken -> Seems fine
- SST: ThimeoKoekError was not initialized in SST. (ptke = NULL, initializer isn't executed), so uMPX encode errors were not shown
- Added new (extra) simple bass clipper
- LQLL: Allow 3 threads instead of 2 (needed for HQ mode on slower systems)
- Sound cards: Add left/right channel swap
- Check clean_NAN -> Fixed, array in Delossifier wasn't initialized to 0, caused weird sound when changing Quality > 100% and (incorrectly) reported NAN error.
- Added MagicRDS AF method A (not tested!)
- Service code didn't print anything to screen due to (probably) Visual Studio .h file changes, solved.
- GUI: If the window is too small (which shouldn't be possible to achieve manually, but might still have happened if set to full screen mode), instead of not drawing, we now just draw in part outside of the visible area.
- GUI: Redraw when warning disappears automatically, also fixes other switches between modes
- GUI: Rename and deprecate Low CPU settings -> Inverted and named to "Heavy CPU (old), under "Compatibility" header.
- Installer: Add shortcuts for run as a service install/uninstall (Still have to do that for the 64 bit version!)
- Linux: 64 bit ARM ALSA build has Jack dependency - removed.
- Check if MagicRDS ASCII mode still works (report received that it's broken) => Works flawless here... Must be a wrong setting.
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha) - Should be solved by new bass clipper?
- Natural Dynamics was broken in the last beta's. Now again same as in 8.54
- Show better license warning (maybe separate icon per used feature?)
- Added sound card input left/right/stereo selection (specific customer request).
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- New skin: Make disabled stuff really gray. Currently it can be a bit confusing.
- Fix unlicensed bottom text (black background)
- Stokkemask crash - waiting for settings
- Create "Warm Dutch" version of Mousse preset
- Remove a bunch of old presets (at least half of them.... list is way too long) BUSY
- Add new presets (8.55 directory)
- Update Analog Pleasure preset
- Check VST Audition 125% DPI behavior -> Ok here, handled by Windows... Not sure what's going wrong.
- Mier
- Josh
- Forward HELP page on web server (installed as well? Also, new URL and view for that)
- When using SCA as a second audio input and in combine/mix mode (ie not in backup mode), LQLL output does not contain the SCA audio input, only the normal input, whereas both FM out and Normal Out outputs has them both mixed as expected.
- Update default preset - maybe for 9.01
- Change RESET behavior to get settings from that preset - 9.01
- Decide to keep or remove new MB clippers -> Remove for now, wait for 9.01
- Put old MB smooth clipper back??? Test with some people...
- DJB plugin build. Mail sent.
- Make separate filter for "warm bass"?
- AVG
- NAS
- MicroMPX NIC selection broken in SST web interface - Koek
- Add MME warning
- Swap Bass EQ / True Bass when both set to between MB's.
- SST: Show warnings
- Website rename Products to Buy
- Display settings (Paul T)
- Muziek uploaden
- Use top part for extra displays (declipper, numbers for MPX level etc)
- VST3 support
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NEW BASS CLIPPER:
Main goal: Warmer mid-bass
In the past, people have complained about bass in Stereo Tool. Different people described completely different issues with it, which made it very hard to figure out what was wrong. With the new compressor mode, that lets far more transients through (including bass transients), the problem was getting worse, and as it turns out, deep bass was suffocating the mid bass. It took until now - and input from 4 different people - for me to figure out 1. what people were hearing and 2. what the solution was.
The key info that lead to this breakthrough was coming from Wes Keene, who reported that the Stereo Tool clipper after another processor does sound warm - warmth was only missing if it was used with Stereo Tool. And in those other processors he had bypassed the finalc clipper - but not the bass clipper. It was the combination of output from Stereo Tool and the Stereo Tool clipper that caused a lack of warmth.
Long ago, I made some (I thought) very smart bass clipper design that would protect higher frequencies against IMD, moreso from deep bass than from less deep bass. When I tried my trick out I expected it to sound bad - but I never heard any issue with it. That, as it turns out, was not really true.... now that I'm hearing the difference it suddenly sounds much better with this new fix.
So, what I did: I added another bass clipper, but a very simple, traditional one. The same type that all the boxes (even analog boxes) used. No smart stuff to avoid harmonics etc, just a stupid, simple bass clipper with a few modes (hard / soft / ultrasoft). If you use that bass clipper BEFORE the existing clipper, it protects the existing clipper from killing mid-bass frequencies if there's a lot of deep bass present, and the new bass clipper adds harmonics that give the sound more warmth and power. On top of these things, there is actually less IMD in the higher frequencies as well now!
This thing isn't completely finished yet, but it should be usable. Most importantly, I need to make it adjust its threshold to what the existing clipper is doing after it. For now, you'll have to do that manually. Also, the default settings may be way off - I have never even noticed that this mid-bass stuff was missing, so I'm definitely not yet an expert in setting this thing up. So I'll wait for feedback from others for that.
NOTE: Bass EQ
New compressor mode info:
PostPosted: Tue Jun 12, 2018 10:30 am
Hello Hans,
Update of the French translation file version BETA089 ;)
