Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 759 posts ]  Go to page Previous 153 54 55 56 5776 Next
PostPosted: Wed Apr 25, 2018 6:41 pm
:D :D :D :mrgreen:
PostPosted: Thu Apr 26, 2018 1:29 am
Stereo Tool 9.00 BETA062
Windows stand alone: http://www.stereotool.com/download/ster ... 00-062.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-062.exe
VST: http://www.stereotool.com/download/vst_ ... 00-062.dll
- Start of song Auto EQ/Bass EQ was too soft: Sudden Jump Protection now only acts when a band is being boosted (that wasn't the case before); effect at beginning is nearly completely gone and overall AutoEQ/BassEQ SJP does far less than before, but is not less effective!
- Sound card high frequency correction: Make sure it always works. -> Not in Ignore high frequencies mode!!!!!
- Fix Matt's GUI crash at a specific size
- FM Analyser pilot tilt problem fixed
- AGC PEQ live updates (when editing) didn't work
- Mono audio on Matt's machine - why?? Wait for .sts files. -> Was a wrong setting, FM Analyser was enabled.
- MicroMPX ifdef stuff
- RDS Compressed flag always set regardless of GUI setting (reported - check first) -> Confirmed, initial load is ignored. - Solved, wrongly initialized, ignored first SetCompresson() call.
- Weird effect for asymmetry -> External RDS input turned Asymmetry off!
- lower output L/R peaks when using external RDS - explained by Asymmetry above
- sg doesn't sound right - probably bad hard limiter Wait for Matt to test
- RDS PS= failure on Swed test files - was ignoring size of commands for other receivers
OLDER CHANGES:
- Fixed preset load error (060)
- NAN logging disabled again
- NAN in equalizer fixed
- New skin
- Fix Basstardizer crash
- Fixed Symmetric Peak
- Max release speed fixed
New AGC mode MORE INFO BELOW!
- RDS: Add PTYN
- RDS: Add timeout for TA
- VST version no 4K
- Backup input - check stereo
- Self test crashes
- Put Bass EQ under license
- Added Basstardizer
- Add low input level warning
- Added ASIO latency setting.
- Fixed (enabled) highpass filter pre-ringing protection.
- We should probably put a warning in the next version if the CPU load is high. Done, but window doesn't nicely disappear (others as well probably)
- Website rename Products to Buy
- Add shortcuts for run as a service install/uninstall
- SST: Show warnings
- Muziek uploaden
- RW, M
- Rivendell plugin build
- DJB plugin build
- NAS
- Start of song AGC etc behavior. Fixed starting point, for AGC
- Quality > 100% extreme CPU warning and recovery
- Quality > 100% Bypass switching causes buffer filling to move
- Add AM presets
- Add new presets
- HPF after MB2 causes too loud bass into clipper (after very tightly limiting it - Bojcha)
- Left Only (dus links naar twee kanalen), Right Only (dus rechts naar twee kanalen, Stereo (default) schakelaar inbouwen in ST
- Array met frequenties versus levels (dus de uitkomst van FFourier) resultanten naar buiten brengen
- Use top part for extra displays (declipper, numbers for MPX level etc)
- Kant
- AGC better LKFS (Bojcha)
- Classical preset
- Test NanoPi
- AM streaming output
- Multi-instance version
- AF method B via UECP
- 18 Hz trigger tone
- Declipper check L-R effects
- Reduce extreme stereo
- Check out Butt
- Omnia.9 test/fix logging
- WatchCat website
- Triple stuff
- uMPX 24x2ch interface
- One bass page
- Talk to chip
- 2 jaar
- Fardau
- -24 dB side chain range?
NOTE: Bass EQ
New compressor mode info:
PostPosted: Thu Apr 26, 2018 8:42 pm
Now I have also received a NaN exception with this version. Here is the text from the log file. As always VST64 Windows.
Exception in: GUI: Saw NAN.
This is not a serious problem but it should not happen.
2a10034  (NSA)
PostPosted: Thu Apr 26, 2018 10:42 pm
2a10034  (NSA)
Ok, I'll run a new build with NAN logging enabled again. Because without that this info isn't enough :(
Did it recover from it?
PostPosted: Fri Apr 27, 2018 10:59 am
Stereo Tool 9.00 BETA063
SAME AS VERSION 062 BUT WITH NAN CHECKING ENABLED
Windows stand alone: http://www.stereotool.com/download/ster ... 00-063.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 00-063.exe
VST: http://www.stereotool.com/download/vst_ ... 00-063.dll
PostPosted: Fri Apr 27, 2018 6:40 pm
de links werken niet
PostPosted: Fri Apr 27, 2018 10:15 pm
Oops! I typed the version number as 855-063 instead of 900-063. Re-uploading now (the text in the title bar will still be wrong).
PostPosted: Sat Apr 28, 2018 1:18 am
:lol:
Garbage in is Garbage out !
PostPosted: Sat Apr 28, 2018 3:08 pm
Tried Beta 63 this morning. Unfortunately, the issue with the audio being different on a track the first time it is run through is still there.
This is with Beta 63 (32 bit VST), and includes AutoEQ + Bass EQ. (Low Level Boost is off, as the change notes didn't mention if this issue should be fixed on Low Level Boost.) The second image is with "Undo" in Audacity, then re-run through Stereo Tool with no settings changed.
Here's the sample.rar, and Beta63_Settings.sts.
PostPosted: Sat Apr 28, 2018 4:26 pm
There is still *some* difference, but it should be far far less than before. I haven't looked at the AGC yet either.
