 Post subject: Constant Buffer problem
PostPosted: Wed Nov 15, 2017 5:46 pm
Hello:
I have ST installed on a computer dedicated to audio processing, but I have buffer problems. After starting ST it begins to slowly lower the Buffer until it reaches the minimum. Then, it begins to cut the sound until it is silenced. After one or two seconds, the buffer is filled again and so on.
My PC Hardware:
Proc: Intel Core i3 (4 cores)
Ram: 4 GB
HDD: 120 GB SSD
My FM Output setting:
Buffer: 1.5000 sec
PD: Declipper is disabled.
Best regards
https://imgur.com/a/btMa2
PostPosted: Wed Nov 15, 2017 6:59 pm
What's the CPU load (shown in Stereo Tool)?
How fast does it happen?
Are you using the same sound card for input and output? Which one is it? Are hou accessing it via Wasapi, Kernel Streaming, MME, ASIO?
PostPosted: Wed Nov 15, 2017 8:17 pm
* Settings:
Quality (CPU Load) Level: 100%
Display Refresh Level: 100%
Rest of Settings: Any
CPU Load Indicator (working): 25% ~ 40%
* It happens every 2 hours approximately
* I use a SoundBlaster input card and a Realtek output card
* I use a WASAPI mode
* I use a Stereo Coder and RDS
Best regards from Chile
PostPosted: Thu Nov 16, 2017 1:45 am
Ok. Cause has to be a different in clock speed between the 2 cards. Stereo Tool will compensate for that, but 1.5 seconds in 2 hours is quite a lot - probably more than Stereo Tool will fix with the default settings.
In the sound card -> input settings, make sure that synchronisation to output is set to Auto or On, and increase "relative adjustment" (by default 0.5%) a bit - for example to 1%. (Actually.. 0.5% should be enough. Not sure here, please check these settings).
PostPosted: Thu Nov 16, 2017 7:29 am
Thanks Hans.
I will try it and publish the result.
