Post new topic  Reply to topic  [ 24 posts ]  Go to page Previous 1 2 3 Next
 Post subject: Re: SoundReturn by GAP
PostPosted: Mon Sep 17, 2018 4:08 am
Any update any time soon??
Cooming soon :!:
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Sep 23, 2018 11:26 pm
First adaptation to ST v9.0x, I listen to reviews ... ;)
GAP_SoundReturn_v0.5.sts [141.88 KiB]
Downloaded 335 times
by GAP
PostPosted: Tue Sep 25, 2018 12:05 am
v 4 vs v 5 5 is like 1 to 2 db quiter
PostPosted: Tue Sep 25, 2018 3:09 pm
Is that good or bad, for you? :)
by GAP
PostPosted: Tue Sep 25, 2018 11:37 pm
That is the only difference I can tell between the 2 versions I am not running the newest version. V4 a little louder is better to me.
PostPosted: Tue Feb 18, 2020 12:11 pm
Any chance to get one more update of these amazing settings??
PostPosted: Fri Mar 06, 2020 2:58 am
This the best settings on the forum IMHO good overall sound a decent amount of bass this sounds really good on my so so speakers. Out of 15 different setting I have tested this one sounds the best. Any chance of getting one more update with a few more tweaks??
i also agree with DJboutit ,i tried many preset but with this i didn't have to change anything.though i did try.
For listening different music on musicbee i use this preset.
I register mainly to say thx for this preset .
i am also waiting for ur next update. :)
PostPosted: Wed Mar 25, 2020 12:22 am
It has been a long, long time ... but hey, the coronavirus and quarantine :) , helped me to have a little time to go back ... I have updated the preset to v9.40, activating new features, I hope you like it and if anything they don't like tell me ;) ...
Thanks to all the comments for expressing just what I am looking for in my preset's.
GAP_SoundReturn_v0.6.sts [118.36 KiB]
Downloaded 123 times
by GAP
PostPosted: Mon Apr 06, 2020 12:42 am
I just tested the newest version on my Shoutcast stream the computer running the radio automation program is hooked up to a Kenwood KR-5030 70s stereo receiver with Polka Audio floor speakers. V6 is decent but not that great I like v4 best. V6 volume is like 3 to 4 db lower bass is like 20% to 25% lower and mids and high is also like 15% to 20% lower than v4. V4 is amazing IMHO V4 is the best for Stereo Tool settings I have ever heard. V4 makes my 96kbps AAC+ stream sound like 35% to 40% better pm for the link to the stream.
PostPosted: Mon Apr 06, 2020 1:19 am
I just tested V5 vs V6 is like V5 is like 2 to 3 db quiter that is the only difference.
