 Post subject: Pre limiter
PostPosted: Fri May 21, 2010 8:31 pm
What happened to it in 5.0 by the way? any chance you could put it back, because i was thinking instead of limiting the sound down by 1db in sam broadcaster, maybe pre limit the sound down by 1db in stereo tool, this is what it did before right? limits sound before any processing?
 Post subject: Re: Pre limiter
PostPosted: Sun May 23, 2010 5:39 am
Hi Matty13,
The pre limiter is replaced by the AGC, which basically is supposed to do the same thing, only better (based on the volume 'as it sounds', instead of looking at peaks in the signal). The next version will contain more AGC improvements.
