PostPosted: Fri May 21, 2010 5:25 pm
Listen:
http://www.zshare.net/audio/76352480327590d6/
I used a preset i found here called deepfm and i changed it around slightly for web radio station, i think this sounds superb but this is only my opinion, it makes it sound just like the original songs but compressed and slightly louder!
[Common]
Pre amplifier=10
Post amplifier=1
Extra loudness=2
Extra loudness - Allow extra highs (advanced)=0
Extra loudness - Punchy=0.224999905
Extra loudness - Max Punch peak=0.75
Extra loudness - Deep bass protection - Value=0.638750076
Bass protection - Enabled=1
Bass protection - Two steps=0
Bass protection - Clip level=140
Bass protection - Deep bass boost=0
Bass protection - Raise clip level if highs get above=150
Bass protection - Maximum clip level raise=35
Hard limit output=1
[Noise Gate]
Enabled=1
Difference=0
Noise level=0.800000012
Relative noise gate level - Band 4=1
Relative noise gate level - Band 5=1
Relative noise gate level - Band 6=1
Relative noise gate level - Band 7=1
[Singleband Compressor]
Enabled=0
Difference=0
Maximum volume=1.5
Attack speed=0.000003096
Decay speed=0.006433673
Above Top Limiter=0
[Pre Compressor]
Enabled=1
Difference=0
Delay enabled=0
Remove remaining loud peaks=1
Maximum volume - Band 1=34920
Attack speed - Band 1=0.000005
Decay speed - Band 1=0.00025
Dual band=1
Relative expected volume of highs=0.649999976
Relative maximum volume of highs=2.5
Remove remaining peaks above (relative to maximum volume)=2
[Multiband Compressor]
Enabled=1
Difference=0
Delay enabled=0
Maximum volume - Band -1=5380
Maximum volume - Band 0=6259.999511719
Maximum volume - Band 1=6750
Maximum volume - Band 2=6940
Maximum volume - Band 3=6850
Maximum volume - Band 4=6310
Maximum volume - Band 5=5670
Maximum volume - Band 6=4990
Maximum volume - Band 7=3720
Maximum volume - Band 8=1560
Attack speeds linked=0
Attack speed - Band -1=0.000090152
Attack speed - Band 0=0.000090152
Attack speed - Band 1=0.000040472
Attack speed - Band 2=0.000010394
Attack speed - Band 3=0.000008139
Attack speed - Band 4=0.000009512
Attack speed - Band 5=0.000011166
Attack speed - Band 6=0.000027837
Attack speed - Band 7=0.000072158
Attack speed - Band 8=0.000132422
Decay speeds linked=0
Decay speed - Band -1=0.000251468
Decay speed - Band 0=0.000200099
Decay speed - Band 1=0.000300077
Decay speed - Band 2=0.000399904
Decay speed - Band 3=0.000399904
Decay speed - Band 4=0.000399904
Decay speed - Band 5=0.000399904
Decay speed - Band 6=0.000399904
Decay speed - Band 7=0.000399904
Decay speed - Band 8=0.000399904
Above Top Limiter=0.639999986
Clipping enabled=1
Postprocessing enabled=1
Relative clip position - Band -1=3
Relative clip position - Band 0=3
Relative clip position - Band 1=2.773584366
Relative clip position - Band 2=2.508771658
Relative clip position - Band 3=2.225806475
Relative clip position - Band 4=1.985074282
Relative clip position - Band 5=1.597402573
Relative clip position - Band 6=1.409638405
Relative clip position - Band 7=1.197802305
Relative clip position - Band 8=1.105262995
Final limiter value=1
Final limiter decay speed=0.000700178
Final limiter clipping=2.508771658
Equalizer enabled=0
Equalizer position - Band -1=1
Equalizer position - Band 0=1
Equalizer position - Band 1=1
Equalizer position - Band 2=1
Equalizer position - Band 3=1
Equalizer position - Band 4=1
Equalizer position - Band 5=1
Equalizer position - Band 6=1
Equalizer position - Band 7=1
Equalizer position - Band 8=1
[Stereo]
Enabled=2
Stereo AZIMUTH Enabled=0
Stereo Image Enabled=0
Stereo Boost Enabled=0
Delay enabled=0
Difference=0
Center bass=0
AZIMUTH limit=59.999996185
AZIMUTH change speed=0.199999988
Image phase amplifier=2
Image phase amplifier maximum separation strength=29.999998093
Image width amplifier=1
Extra phase shift=0
Mono or stereo only=0
Stereo Boost strength=1
Stereo Boost maximum amplification=3
Stereo Boost multiplier=1
[Channel Delay]
Enabled=0
Left Delay=0
[Output Filter]
Enabled=0
Lowpass filter=15000
Highpass filter=29.999998093
[Bass Boost]
Enabled=1
Strength=0.252900004
End lowpass frequency of input filter=250
Start lowpass frequency of output filter=250
End lowpass frequency of output filter=350
Clip level=1.5
Preserve louder peaks=1
Difference=0
[Phase Rotator]
Enabled=0
Start frequency=700
Start speed=1400
Number of rotations=4
Smoothness=0.979999959
[Final Limiter]
Enabled=1
Difference=0
Pre-amp=1
Pre-limiter enabled=1
Pre-limiter relative volume=1.75
Reduced CPU processing=0
[FM Transmitter]
Enabled=0
Pre-emphasize=0
Pre-emphasis time=75
Output is pre-emphasized=1
Stereo encoder enabled=1
RDS encoder enabled=0
Pilot signal volume=9
RDS signal volume=4.5
FM overdrive volume=1
RDS PS text=2s:STEREO/2s:TOOL/<1=1.5s,2..-2=2t,-1=1.5s:WWW.STEREOTOOL.COM/1s:\T2h\:\T02m\:\T02s/1s:\T2h\.\T02m\:\T02s/1s:\T2h\:\T02m\:\T02s
RDS RadioText text=60s:Stereo Tool: Professional Audio Processing - www.stereotool.com/30s:Stereo Tool by Hans van Zutphen, 1999-2008 - www.stereotool.com
RDS PTY=0
RDS PI=65535
RDS Alternative frequency 1=0
RDS Alternative frequency 2=0
RDS Alternative frequency 3=0
RDS Alternative frequency 4=0
RDS Alternative frequency 5=0
RDS Alternative frequency 6=0
RDS Alternative frequency 7=0
RDS Alternative frequency 8=0
RDS Alternative frequency 9=0
RDS TP=0
RDS TA=0
RDS Music=1
RDS Artificial Head=0
RDS Compressed=1
RDS Dynamic PTY=0
RDS RadioText Enabled=1
RDS ClockTime Enabled=1
[Direct soundcard access]
Enabled=0
Volume=1
Buffer size=5
Send to Winamp=Nothing
ASIO Override channel 1=4
ASIO Override channel 2=5
[Low latency output]
Enabled=0
Volume=1
Buffer size=0.079999998
ASIO Override channel 1=2
ASIO Override channel 2=3
