PostPosted: Mon May 17, 2010 7:23 pm
HI from Greece , i have an old fm transmiter 100w, with only one RCA for audio input and i like to now if i can use the ST for stereo coder and rds !
i read the help page , and i like to now if i can use it with ESI MAYA44( 192khz ok)http://www.esi-audio.com/products/maya44/ audio card !
i have the radio station just for hobby i must by the ST to use it ?
and one more , my set up is :
one PC with the audio card maya44 for filtering the sound with a music program,
one mixer
one laptop that plays the music .
i take the sound from laptop to in of pc and the out of pc to in of the mixer and the master out of the mixer to in of the transmiter.
i don't now if that is the best !!!
with ST can you tell me how the conections sould be ?
p.s.
sorry for me bad english.
Vanilla Radio
Vanilla Coffee & Lounge Bar Greece
manager.vanilla ( @ ) gmail . com
|| http://www.vanilla.gr || http://www.vanillaradio.com || http://www.vanilla-lounge.gr ||
PostPosted: Mon May 17, 2010 7:43 pm
Welcome George,
Yes. Assuming that the transmitter does not filter out or otherwise process (boost, pre-emphasis) the high frequencies.
Yes.
Well, if you don't you'll get a spoken message every 4 hours...
one mixer
Don't use a mixer after the Maya44. The output of the Maya44 should be connected directly to the transmitter, with a good quality cable - and a shorter cable is better.
PostPosted: Mon May 17, 2010 7:57 pm
[/quote]
Don't use a mixer after the Maya44. The output of the Maya44 should be connected directly to the transmitter, with a good quality cable - and a shorter cable is better.[/quote
thanks for you answer , the ST in witch computer sould i install ??? in pc or in laptop ?
p.s.
the pc is with the maya44
thanks again i all ready register
Vanilla Radio
PostPosted: Mon May 17, 2010 8:04 pm
In the PC! The signal from the Maya must go directly into the transmitter, so if you want to use both a laptop and a PC, then the Maya goes into the PC.
Thanks for registering :-)
PostPosted: Mon May 17, 2010 8:10 pm
so the set goes like this ...
the line out of laptop with winamp or any other program for broadcast goes to mixer and the out of a mixer to in of pc with maya44 and ST , and the out of pc to transmiter .
is that corect ??
sorry again !
Vanilla Radio
PostPosted: Mon May 17, 2010 8:30 pm
Yes, That's Correct!
Later you can use another Lapotop or pc or Cd Player or any other source, to connect it to mixer.
Point is that Master from mixer must go in Maya's input > processed by Stereotool > and Output from Maya to transmitter.
Choose Maya's L or R output for Transmitter.
PostPosted: Tue May 18, 2010 4:01 pm
HI AGAIN , I NEED MORE HELP.
I MAKE AL THE CONECTIONS I HERE THE MUSIC FROM RADIO BUT NO STEREO OR RDS , CAN YOU HELP ME WITH CALIBRATION OF THE PRGRAM ???
MAYBE WITH TEAM VIEWER ??
THANKS
Vanilla Radio
PostPosted: Tue May 18, 2010 10:17 pm
THANKS
Please check:
0. In the FM settings window: Stereo encoding and RDS encoding enabled? And you're really using the FM output, not the normal output?
1. In the Maya44 settings window: If the output sample rate is really 176.4 or 192 kHz
2. In the Stereo Tool FM window (sound cards window in Stand Alone version): If there are errors reported (see top left of the window)
3. If this is all ok: Is the stereo LED of the receiver on?
If (3) fails: Then the transmitter is probably filtering out higher frequencies. Also, if you have "FM Pre-emphasis" enabled, do you hear far too much highs in the output? If so, then the transmitter is also pre-emphasizing, which it also shouldn't.
PostPosted: Wed May 19, 2010 8:31 am
THANKS
Please check:
EVERYTHING ITS OK .
THANKS
Vanilla Radio
PostPosted: Wed May 19, 2010 10:23 am
Can you tell us what was wrong? That might help someone else who has the same problem... Or, if something is unclear, help me to improve things.
