 Post subject: Aussie - Coastal Dreams
PostPosted: Tue Aug 15, 2017 2:21 pm
ST Type: Standalone
ST Version: 8.41 Beta 047
ST Licence: Pro (Everything) + new Advanced Dynamics
ST Profile: ST_841B047_v2 - Aussie - Coastal Dreams (~6dBr) (FM).sts
ST Dest: FM Output
Typical Top 40 Short LKFS: -9
Profile Use: Top 40, Rock
Comments:
You wanted bass..... so you got it!
Latest Coastal Dreams. Should be all good to be used an full anger and take full use of the new Advanced Dynamics!
Have fun!
PostPosted: Wed Aug 16, 2017 3:17 am
ST Type: Standalone
ST Profile: ST_841B047_v3 - Aussie - Coastal Dreams (~7dBr) (FM).sts
ST Dest: FM Output
Profile Use: Top 40, Rock, Easy listening
Comments:
Yet further fine tuning. Loudness upto ~7dBr with Top 40 for FM use.
As before, can be used an full anger on air for sound testing and take full use of the new Advanced Dynamics.
Dont forget to purchase the new feature licence.
Have fun!
PostPosted: Fri Aug 18, 2017 12:33 pm
ST Type: Winamp
ST Profile: ST_841B047_v4h - Aussie - Coastal Dreams (~7dBr) (FM).sts
ST Dest: FM Output
Comments:
Yet further fine tuning pushing bass and much wider airier sound to reduce bass fatigue. Loudness upto ~7dBr with Top 40 for FM use.
If using in a live situation, you need to import in parts.
1. Reset All Configuration settings, and then import All Configuration settings from the file
2. Reset All Processing settings, and then import All Processing settings from the file.
3. Click on Limiting & Clipping, Reset All Limiting & Clipping, and then import all Limiting & Clipping settings from the file.
4. Carefully manually check the Limiting & Clipping settings, especially in the Advanced Clipper. I found the Composite Strictness and True Peak dont import correctly. These are set to 10 in the profile.
Oh, dont forget to purchase the new feature licence.
Have fun!
ST_841B047_v4h - Aussie - Coastal Dreams (~7dBr) (FM).sts [106.04 KiB]
Downloaded 601 times
PostPosted: Fri Aug 25, 2017 2:08 pm
Profile Update
ST Type: Standalone
ST Version: 8.41 Beta 050
ST Profile: ST_841B050_v1a - Aussie - Coastal Dreams (~7dBr) (FM).sts
ST Dest: FM Output
Profile Use: Top 40, Rock, Needing to be outstanding
- Re-enabled Azimuth
- Restored Stereo Image width
ST_841B050_v1a - Aussie - Coastal Dreams (~7dBr) (FM).sts [108.19 KiB]
Downloaded 535 times
PostPosted: Sat Aug 26, 2017 12:56 am
Thanks for your work on these, Paul. Sounding great on our station.
PostPosted: Sat Aug 26, 2017 2:32 pm
Thanks Beej6. Always a work in progress.
PostPosted: Thu Oct 26, 2017 1:17 am
Profile VARIATION
ST Type: Standalone
ST Version: 8.52 or later
ST Profile: ST_852_v2(loud) - Aussie - Coastal Dreams (~8dBr) (FM).sts
ST Dest: FM Output
Typical Top 40 Short LKFS: -8
Profile Use: Top 40, Rock, Needing more rhythmic bass
This is a variation to the earlier Aussie Coastal Dreams where I have been pushing the levels to gain additional bass thump. Stokkemask filter is now disabled in the profile.
ST_852_v2(loud) - Aussie - Coastal Dreams (~8dBr) (FM).sts [108.27 KiB]
Downloaded 523 times
