 Post subject: Stereo Tool 8.33 BETA
PostPosted: Tue May 09, 2017 9:05 pm
Here's a new beta with a number of bug fixes (most of which are very rare or don't seem to have any effect, but it's good that they are gone regardless):
Windows stand alone: http://www.stereotool.com/download/ster ... 33-002.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 33-002.exe
VST: http://www.stereotool.com/download/vst_ ... 33-002.dll
CHANGES
- Error 409 - caused by big memory allocations on stack in web server for SST interface -> Should be fixed
- Use area 0 issue: Loading Wes Keene's Eleven Heaven preset and then enabling Stokkemask caused exceptions due to a bad setting without protection -> protection added.
- Assert when switching latency (Jeroen Platenkamp's preset). Possibly related to NAN error. Looks like a WindowInfo is overwritten while it's still being used.
- SST license mechanism
TO BE DONE FOR RELEASE:
- SST replace recording!
- Clock time with jumps for uMPX? - WORKAROUND added
- Check identical sound cards.
- Name the target OmniaSST.exe
- 409 issue
- Web interface issues (long strings)
- Too big packets
- License generator to Jim
- Values go back?
FUTURE:
- EQUALIZER CHANGES
- RMS same behavior for DC Waiting for feedback
- Triple WAIT FOR FEEDBACK
- SST upload / confirm / download / delete presets
- uMPX web interface
- Test clipping
- Classical music compressor
- RDS word wrap chance for ArcticPalm: Split words if needed. Dave Hartman.
- Clipper "Prioritize loudness" mode. Tested and seems to work, fine-tuning needed.
- Fix anti-phase. Tested and seems to work, needs to be implemented to always work.
- NAB
PostPosted: Wed May 10, 2017 10:14 pm
Did someone try to load my preset and use it with Stokkemask? Or were you just testing something and found that bug?
PostPosted: Fri May 12, 2017 2:05 am
2 people reported crashes. In some places Stokkemask is mandatory, so people will turn it on.
PostPosted: Fri May 12, 2017 2:07 am
Gotcha. Just curious if I had a new station.
PostPosted: Sun May 21, 2017 12:08 pm
The sliders drive and output level in singleband compressor seem not to work properly, if advanced above +10dB no amplification is achieved and I've found the output bit depth when using AM transmitter output is 16bit and when swiched to FM trx, that increases to 24bit, is it normal?
I'm running the latest version as a winamp dsp plugin
