Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 233 posts ]  Go to page Previous 18 9 10 11 1224 Next
PostPosted: Tue Oct 06, 2015 6:12 pm
I have AMD K6-II !
Eh... Bojcha :D
AMD clone of Intel's 80286 ;)
PostPosted: Tue Oct 06, 2015 6:22 pm
Yes, it will only show a picture of ST :D
But if interested i have Pentium I 100 Mhz :) and a Cyrix at 66Mhz
PostPosted: Tue Oct 06, 2015 8:11 pm
Hi Hanz,
Which sound card will work with the raspberry version ?
A good sound card USB ? 192 khz for MPX signal
Thanks
I don't know yet. There are 192 kHz cards available (at a very low price even) but I have no idea yet if they are any good.
This might work (NOT TESTED!!!):
http://tweakers.net/nieuws/94783/wolfso ... ry-pi.html
Unfortunately jackd not supported I2S DAC :(
PostPosted: Tue Oct 06, 2015 10:31 pm
I have a friend works at computer firm. He CONFIRM to me that intel is a SLOW motion SNAIL !
So i3 (2 CORES) to be better than 6 core CPU is the most stupid thuing i`ve ever heard !
FX-4300 vs. a fast i3:
http://cpubenchmark.net/compare.php?cmp ... cmp[]=2351
Most important part:
Single Thread Rating: FX-4300: 1411 i3: 2228 - so i3 single thread is 58% faster!
CPU Mark FX-4300: 4639 i3: 5576 - so i3 in TOTAL is still 20% faster!
The AMD also uses a lot more power. It is also older and cheaper, so maybe not a very honest comparison. But a dual-core i3 can definitely be faster than a quad core AMD.
Ah. That's going to be a problem for that card as well I suppose :(
PostPosted: Wed Oct 07, 2015 8:54 am
Thank you, Hans - this is exactly what I was talking about :) I was comparing to i3-3220T, which is downclocked (and only 35W!). Additionally, as I said - FX4300 is NOT a true 4 core chip. It has 2 modules (2 integer and 1 floating point units per module). So in total it actually has 4 integer units and only 2 floating-point capable units. Hence, FPU-wise it's a dual core!
PostPosted: Fri Oct 09, 2015 7:17 am
it`s 4 cores, but two by two are sharing same recources . It`s NOT like 2 "virtual" cores. They are phisically there , but share the L3 and L2 cache. But it`s different from what Intel "do" with these virtual threads . note i said threads , not cores !
Here is the explanation
http://wccftech.com/review/amd-fx-8350- ... or-review/
PostPosted: Fri Oct 09, 2015 11:38 am
They share not only CACHE (shared CACHE is a common thing in CPUs). They have 2 modules 2 cores each (In 4 unit CPU's, which are marketed as cores). But in total only 2 FPU units. Instead of 4 as in regular CPU's. So are they 4 core CPU's? Yes integer-wise and no floating point-wise. Of course Windows and any other system will show you 4 threads. As in i3 for example, which is hyperthreaded dual core.
A real problem with those CPUs is that the OS doesn't recognize its modular structure. So the OS thinks it has regular 4 cores. Which is not true (in normal scenario 1 core = 1 FPU and 1 integer, in FX 1 module = 2 cores for which there's 2 integer and only 1 FPU). This is why some power is being wasted on CACHE storing the data for floating point operation (system thinks there are 4 FPUs). It's actually some kind of multithreading that the OS is not aware of. Also it tends to perform slower in Windows than in Linux (according to benchmarks, however I didn't test the last one myself).
Vishera uses exactly the same module structure as Bulldozer, and looks like this:
See: 1 module = 2 integer units, 1 floating point (FPU) - and those share 2048 kb CACHE.
PostPosted: Fri Oct 09, 2015 7:25 pm
This explains a lot of complaints that I have seen from AMD users who mentioned getting very different multithreading behavior when they restart Stereo Tool.
PostPosted: Sat Oct 10, 2015 10:17 pm
I googled some info:
" And some important notes:
I haven't included the mmap patch, this is already supported in the upstream kernels but currently disabled by default. To enable mmap support add the following line to config.txt:
dtoverlay=i2s-mmap "
And now stereotool is starting up, but the cpu usage is 50% constant.
I only want to use the FM part of the software. I want to generate ST+RDS signal.
