Post new topic  Reply to topic  [ 183 posts ]  Go to page Previous 18 9 10 11 1219 Next
PostPosted: Wed Jun 11, 2014 2:03 am
Does anyone have a good C-QUAM clipping description? What I found online is something like this, but the details are unclear:
1. Clip L+R as normal, including asymmetry.
2. Clip L-R. Not asymmetrical. But I don't know if the peak level must be at 100% or higher. Also, I don't know if I need to lower the clipping level to make room for the 25 Hz tone that's added to aid AM stereo detection.
3. L and R apparently need to be limited (or clipped) below a certain level as well. I only find something about a level at the bottom, not at the top, which seems odd.
PostPosted: Thu Jun 12, 2014 11:15 am
Post moved here.
PostPosted: Thu Jun 12, 2014 1:34 pm
STAND ALONE: http://www.stereotool.com/download/ster ... 43-008.exe
FIXED:
- Lower CPU load when using streaming with low pre-emphasis values. "Hole protection" must be set to LQ mode if it's disabled for non-preemphasized audio.
- Make SCA frequencies configurable for HAM radio
- Real watchdog behavior: Regularly check for sound card input & output
This watchdog behavior works as follows: If you enable the check, it will act if no audio passes through an enabled audio input or output for more than 1 minute. If so, it will trigger a 'RESTART SOUND CARDS' button click. It will attempt this 4 times, if NO DATA passes through the sound card AT ALL during all these attempts, if the 'Restart' watchdog setting is enabled Stereo Tool will close and a new instance will be started.
NOTE: Important potential issue: If Stereo Tool hangus during closing, it could be that new instances are started all the time until the PC memory is full... I will check if there's a better way to fix this. ---> IS FIXED NOW, WILL BE OK IN THE NEXT BETA.
NOTE #2/BUG REPORT: I just realized that the ASIO code is not working yet! So if you use ASIO the restarting behavior will be triggered all the time. It's a good way to test the behavior though...
TO DO:
- Support ASIO as well in the watchdog
- Improve restart behavior (make sure that the old instance is really closed).
- Show Lowpass filter freq in AM panel?
- C-QUAM?
OLDER CHANGES:
- Added restart-on-crash behavior (enable 'Watchdog' in the Configuration panel).
- Fixed one weird hangup in VLC output when passing bad parameters
- Added option to pass extra parameters to input VLC (just type them after the URL).
- Carrier at +/- 19khz on the AM band. Just turning the FM off doesn't kill the stereo pilot. (fixed in 004)
- I again will say here that there is something wrong with Calibration section . Three options are identical with what they do : Test right silence , Test SSB lower and Test SSB higher. Nevermind what option you check, they causes same display behavour and same result as audio. --> NO, they are very different if you look at the actual output. Display is generated before calibration. Actual output does contain SSB or LSB audio.
- At the new Normal output settings there is a problem with "Input without processing" option . Sound is gagged/strange / I'm not at my Stereotool pc at the moment but when using a pipeline input and normal & fm output (192 kHz) , I noticed a strange effect when switching the normal output to bypass. Sounded like it could be a sampling rate thing? - Worked fine in some cases but not in others. I think it's fixed now.
- I think I also noticed a small typo - check the AM transmitter window.
- On the thorium preset it plays fine and then gets garbled and sounding like a 45rpm song playing on 33 rpm. cpu load is just 26% the rest of the presets work fine. (waiting for feedback, unable to reproduce it). --> Multipath Clipper is enabled in this preset. That explains the higher CPU load.
- VLC output still hangs on outputs that don't work (for example an invalid ShoutCast address). Probably because no data is sent through the output path, which causes the same stop hangup again. --> If Status is STOPPED, ERROR or NOTHINGSPECIAL, I don't call STOP or RELEASE. This seems to cause a small memory leak (a few kB probably) every time it happens, so it's not ideal. But better than a complete hangup. Still waiting for feedback on a question in VLC's forum.
- Add VLC output error detection & re-connect behavior (if possible without resetting the other inputs/outputs).
- VLC input: But something is strange sometimes plays like 1 or more samples delay between channels, occurs highs cancelation when switch to mono. I checked everything including exact mono sound input. -> Output was already running before connection was established. That's ok, but the start sample must be left channel -> fixed.
- VLC input with Low Quality Low Latency output hangs -> Solved by disabling LQLL output when VLC is used for input (which makes it impossible to reach low latencies anyway)
- VLC MP3 output. No room in current settings window... -> You can now add more options in the SOUT string (space separated)
4. Turn AM stuff off if FM is enabled (?) but what about asymmetrical clipping/limiting for FM? -> Extra switch in Expert mode
5. Add pre-emphasize output button for AM pre-emphasis
Fixed the mentioned and some other bugs in the previous beta. All combinations of settings seem to work now.
- Normal Output can now be partially separately processed for FM output. So you can generate, for example, a composite clipped 75 us pre-emphasized FM signal and a not or far less pre-emphasized signal for streaming, or a separate FM signal without composite clipping to feed remote transmitters, in the same Stereo Tool instance - no more need to run a separate copy for the stream! Only the clipping and limiting is done separately, so the CPU load does not go up much. Note that the lowpass filter can not be specified separately (lowpass filtering happens much earlier in the sequence and using different values would require doing almost all the processing twice).
- AM section now contains an 'AM Transmitter' Enabled switch.
- Headroom slider added to the AM section. No more need to abuse the Post Amp slider to create headroom for asymmetrical output. (Note: It's also not possible anymore, so you need to update your settings if you use AM).
- AM pre-emphasis checkbox added in the AM section, so you don't have to abuse the FM pre-emphasis anymore.
- AM pre-emphasis curve (which is slightly different from the FM curve) is now correctly implemented.
- AM signal can now go through the FM sound card output (it's now basically an FM/AM sound card), including tilt correction etc.
PostPosted: Sat Jun 14, 2014 6:40 pm
STAND ALONE: http://www.stereotool.com/download/ster ... 43-009.exe
WINAMP/DSP: http://www.stereotool.com/download/dsp_ ... 43-009.exe
FIXED:
- Memory usage of stand alone version reduced.
- Merged in older changes in a separate branch. should not have any noticeable effects.
TO DO:
- C-QUAM?
- Add Pirate License (3 days)
OLDER CHANGES:
PostPosted: Sun Jun 15, 2014 9:22 am
I had to step away from playing with ST for the past year, but I come back...and Hanz, you are contemplating C-QUAM? Seriously? :o
PostPosted: Sun Jun 15, 2014 1:33 pm
It shouldn't be too difficult, so why not :) I just need to find a good description of what the signal needs to comply to exactly.
PostPosted: Sun Jun 15, 2014 7:17 pm
Afaik you need an AM Transmitter that has the ability to modulate LSB and USB separately, which is Not so common...
PostPosted: Sun Jun 15, 2014 7:58 pm
Sliggtly different, but yes you need a special transmitter. Anyway, all I need to do is clip slightly differently.
PostPosted: Wed Jun 18, 2014 3:48 pm
The AM Stereo system in the USA doesn't use separate USB and LSB for the Left and Right channels. When they were hashing this out 30 years ago, there was a system that did do it that way but it's not in use any longer. The transmitters accept Left and Right inputs like an FM stereo system does. I want to say that the L+R is processed separately from the L-R but I've never fully understood that part of it.
PostPosted: Wed Jun 18, 2014 4:00 pm
What I understood is that L+R is processed normally (so normal AM receivers will get that output, with asymmetrical clipping and everything), L-R is processed separately but due to the way it's encoded I think it's not asymmetrical. So far it's easy (I can just feed my clipper with L+R and L-R audio and make one channel asymmetrical). But apparently, when audio gets merged together again in a receiver, depending on the receiver this can result in overshoots (hence distortion) as well and something needs to be done to handle that. That's the part that I didn't fully understand yet - I only found a reference that something needs to be done but not what exactly.
