Post new topic  Reply to topic  [ 172 posts ]  Go to page Previous 18 9 10 11 1218 Next
PostPosted: Wed Apr 28, 2010 12:28 pm
Those things are otherwise solved in this boxes and not in this way.
Gating I suppose? That's on my todo list for a future version...
PostPosted: Wed Apr 28, 2010 3:28 pm
Hans , the setting is at 2 seconds , thats the default setting and looks good .
I`ve tested this setting at lower (0.1-0.5) and higher (4-5 sec) and looks good at default setting of 2 seconds.
And Hans , I think that if this setting is set to more time , this causes in dinamic songs or balads or sometning to hold the gain stable for this period of time ( not to go low or high ) . It`s very important for songs with dinamic sound . 2-2.5 seconds will be enough . It`s ok to use regulation of this setting right ? :) I think You agree with me
PostPosted: Wed Apr 28, 2010 3:47 pm
Hello Bojcha
You don`t make sence between attacking the voume with time constant and regulate volume gain isn`t it ?
I know that Stereotool is doing what needed ( thatswhy i like it ) but the method is not right :) I think that I`m clear now . I explain this to Hans and I think that He`s realize it :) The gain must be SET for each song , depend on highest part ...to avoid the feeling of changing the gain where no bass for example :) You understand?
I am understand you now completely.
So tell me. what Broadcast processor is doin' that ? afaik the most popular processors (box) are Omnia, Orban, vorsis.. etc...
I can tell you. Neither does. Even Omnia 11 and Optimod 8600. It's simply why, because latency.
Bojcha , the thing is that the sound of broadcast must be softer and limited good , because the modulators are not very stable on saturated sound or levels or kind of peaks that causes distortion and "out of deviation limits" effect ( mean +-75 Khz) this is handled by Low frequency signal bandwidth and his level :)
Above this limits the receiver is out of range (the transmitter still do his jobs , no problem , but the receiver ........ ) Hans knows this perfect :)
In stereo tool we have in theory more and more processor power then any other hardware device with processor ..(say 100-200 Mhz like DSP or something) , so the sound here must not be compressed or some kind of shitty sounding , Processor Power is enough :)
PostPosted: Wed Apr 28, 2010 8:29 pm
Hans Monday was a very sad day for Stereotool
http://www.crunchgear.com/2010/04/26/so ... -30-years/
According to me Stereotool was the only professional soundprocessor that fitted on a 1.44MB floppy.
PostPosted: Wed Apr 28, 2010 8:35 pm
ha ha ha ha
Luke buddy are you kidding man.
Floppy disk ...... there are many flash memory out there and you may fit Stereotool about million times :)
and .... flash memory is smaller than floppy disk :)
PostPosted: Wed Apr 28, 2010 9:02 pm
ha ha ha ha
I had to read twice and slap myself in the face. I thought I was in a time warp :-)
The size of ST shows how well coding can be done without waisting space.
PostPosted: Wed Apr 28, 2010 10:23 pm
v4.22 can fit on 1 side floppy 720 :P
PostPosted: Wed Apr 28, 2010 11:34 pm
Exactly, good analysis.
PostPosted: Thu Apr 29, 2010 1:40 am
Damn :-(
I thought I was ready to release Stereo Tool now. But... Apparently there has been a performance drop in the last few days. So I want to check what's causing that first.
Latest version is uploaded as BETA (NOT BETA2!!!), use the link in the first post of this thread.
Today's changes:
- Warning pop-ups for low latency and FM processing, warns about lower quality if this is enabled.
When the performance is restored I'll release Stereo Tool 5.00.
PostPosted: Thu Apr 29, 2010 7:06 pm
Hans , a little question about Stereotool ?
In 64bit system instalation of Stereotool goes to Program Files(x86) , witch means still 32bit program ...... Any idea for 64bit Stereotool ? Is it possible?
