Post new topic  Reply to topic  [ 1012 posts ]  Go to page Previous 185 86 87 88 89102 Next
PostPosted: Sat Mar 16, 2013 3:03 pm
"- Still silence using Synchronize option to normal output "
I'm not sure if something was modified in this version regarding this, but this is now working on my side.
Bart
Web: http://www.contact-dance.com
Request system: http://www.contact-dance.com/c-request
FB page: https://www.facebook.com/ContactDance
PostPosted: Sat Mar 16, 2013 3:13 pm
Could you send me your settings? It should really work now - and I've tested it on 2 different PC's and it works fine on both.
PostPosted: Sat Mar 16, 2013 4:06 pm
For the record, all presets includind '80style' that uses knee, now sounds fully different!
Still not sure is knee working as should, will check later..
PostPosted: Sat Mar 16, 2013 4:31 pm
I knew it....
Look at this :
http://www41.zippyshare.com/v/49248076/file.html
Download and watch if web player cannot run it
PostPosted: Sat Mar 16, 2013 4:43 pm
I knew it....
Look at this :
I did, this doesn't have to be a problem though. The question here is: Does it *sound* bad/different?
See, if nothing happens (no resampling), the original samples values are displayed. But they are clipped, an oversampled display would look very different.
When resampling happens, we see 'in-between' sample values, similar to what happens with oversampling. And sometimes we do see them and sometimes we don't. This is not bad or wrong though - again, unless it sounds different.
PostPosted: Sat Mar 16, 2013 5:37 pm
I don`t know if it`s sound different... i think NO. Or i cannot hear it.
Let`s say NO .But found something.
for the "wave shaking" issue.
So when second band is at the level of first band - it seems good, but when i put the signal only covered by the first band ... you know that second band goes up cause of no signal (or it only have low signal and must be amplified ). The more UP "second band" goes, the more shaking appears...
Bojcha, please do the test and let us know if you have the same .filters steep is 32 all of them. First band 40 hz , second band 90 hz.
PostPosted: Sat Mar 16, 2013 6:26 pm
Ok for first time i wanted t try that Sync...
Since on stream input is Realtek HD input (spdif) and outout is VAC.
They can never have exact same ratio and after some time buffer will gone or overfill (in this case gone)..
Anyway i was fixing that with more buffer.. and buffer restart appiers about once in 2 days.
Wanted to use asio first but for some reason realtek spdif does not work as sould with asio4all,
Then i tried sync and i had no audio.. Installed last beta55 (was 51) and now i have audio.
First what i notice is too much chasing.. sync constantly tries to "sync' but i know that there is no too much ratio difference between those 2 cards.
So with "relative adjust" slider to 0.10% seems to be much better.
What is "M" and "x" ?
x stays most of time to 1.000
and M is (after some time) around 1.0080 - 1.0100
PostPosted: Sat Mar 16, 2013 6:55 pm
X means x(multiplied) like 2x5=10
1.0000 is related to the Output i guess....
So when output value is equal to 1.000 , then input must be multiplied or edited/resampled by M= to match the actual value.
This is the logical explanation.
Wow my x is under 1 .... like 0.9982 0.9988 ...
PostPosted: Sat Mar 16, 2013 7:22 pm
I think you misunderstood me Hans.
It IS working now. (het werkt nu).
Bart
Bart
PostPosted: Sat Mar 16, 2013 9:23 pm
This is true: As long as all the bands are at the same level the output is equal to the input, and hence there are no 'wobbling' effects. The bigger the difference between bands, and the steeper the filtering between those bands, and the closer their frequencies are, the stronger the wobbling will get.
That's why in the old multiband I had this 'steepness protection' that didn't allow mainly low frequency bands levels to get too far apart.
