I've measured the difference using 'FM Loud Europe (Bass)', because with that setting nearly every filter is turned on and is used aggressively (ANY difference causes big differences in the output).
This sounds reasonable, but ....
But in practice it is getting difficult to tell any difference (to hear or to watch the GUI meters) with such a heavy processing at all.
Please try it with my
TranS-EnhanCe HiFi Full DR100 preset !
And something like
Duran Duran - Wild Boys or whatever you have (as long as you use my preset !).
Michi: Is it possible that the differences are caused by the programs that you use to send the audio?
I don't think so.
As I already have written it happens in Wavelab and with BA Live.
Concrete:
I can use three instances of Stereo Tool at the same time:
One DSP Beta70A hosted with BA Live (FX slot 1).
One DSP Beta70A hosted with the Acon chainer using xlutop's DSPtoVST wrapper (Acon chainer FX slot 1).
The Acon chainer VST (wrapped by Cakewalk VST Adapter to DX) is hosted with VB FX-4 (winamp DSP version) and this is hosted with BA Live in FX slot 2.
(You don't need the Cakewalk VST Adapter $ and can use the native Acon DX version instead !).
And finally native VST Beta70A loaded in Acon chainer FX slot 2.
So I can use any player I want (winamp, foobar, J.River or whatever).
And using my
TranS-EnhanCe HiFi Full DR100 preset (of course all quality sliders up and same sample latency) the two DSP versions sound almost the same (I cannot hear or see a difference).
But the VST version output is obvious different.
It is so obvious, that I agree that is not necessary to measure it by comparing written WAVs bit by bit (though I understand your problem Hans, that you must measure this difference somehow before any further steps - the question is: difference ? Or no difference ?).
But even my sister notice it (and she is really a stupid girl in other situations of life).
Maybe not with
FM Loud Europe (Bass) preset, but with my preset (DR100 !) it is there !
So, if it would be only me who complains.
But phoenix agrees that there is this difference.
Where is Bojcha when you need him ?
Bojcha ?
Difference VST versus DSP or no difference ?
@ all
Try it especially with my DR100 preset !
