Post new topic  Reply to topic  [ 2125 posts ]  Go to page Previous 180 81 82 83 84213 Next
PostPosted: Fri Jun 24, 2011 6:10 pm
I did not even listen to it
Try it out, it's really a great track (if you like gabber music, that is).
I'm sure that it is listed in the Geneva Conventions somewhere that it is not alowed to play 'this' on the radio or anywhere else!
Bojcha, this will be the Baby : ASRock Z68 PRO3-M , Intel® Core™ i5-2500 and 8GB of memory and an SSD drive
PostPosted: Sat Jun 25, 2011 2:51 am
BETA072:
- Found yet another bug (or actually 2) in the declipper that affected the audio quality. Fixed! CPU load should be roughly similar to before. Improvement in reconstruction is clearly noticeable...
Winamp DSP plugin: http://www.stereotool.com/download/dsp_ ... 20-072.exe
Stand alone version: http://www.stereotool.com/download/ster ... 20-072.exe
VST version: http://www.stereotool.com/download/vst_ ... 20-072.dll
VST version (No SSE2): http://www.stereotool.com/download/vst_ ... 20-072.dll
Command line version: http://www.stereotool.com/download/ster ... 20-072.exe
Linux command line version: http://www.stereotool.com/download/ster ... ETA620-072 NOT AVAILABLE
Linux GUI version: http://www.stereotool.com/download/ster ... ETA620-072 NOT AVAILABLE
- Fix Punch
- Fix crash at program close
- Reduce Loudness CPU load
- Scopes black background?
- Add AGC start level
- Save bandpass filter order
- Declipper: Fix loud bass with soft higher frequencies issue. Do something with loudest frequency vs. peak level - if it cannot fit (Madonna, Metallica) there must be clipping, otherwise there might not be. On top of this I should somehow try to preserve deformed bass sounds (if they are not hard clipped). Maybe this will work: Find loudest frequency, if it's very low. Than assume that it's clipped at the maximum restoration level (?); generate a new tone (using lowpass filter) of the same frequency and clip that at some margin below the maximum peak level. Then filter the input signal based on the FFT of the clipped signal. Finally analyze this new signal; if it is indeed clipped the filtered output will resemble a clipped waveform (visible in sample histogram; no tilt issues!) instead of a sine wave. Use the output of this as input to determine how strict the clipping detection for the input waveform should be (eg. based on normal or sinusoid signals). This is all way too difficult and it just won't work. Here's the real solution: Detect if a loud bass sound is present, if so make sure that symmetrical clipping detection is used, possibly with automatic 'maybe clipped' level adjustment. This should only slightly affect Metallica (which still sounds very reasonable with symmetrical enabled), but has a big effect on DBN - Jack is Back (which is far less affected with symmetrical enabled; auto likely/maybe adjustment based on symmetrical should help even more).
- Natural Dynamics: Save settings in VST version[/color]
- Release 1 hour
PostPosted: Sat Jun 25, 2011 10:52 am
Hans ,
Yes For the "filter order" in bandpass filter panel . I found a couple a days ago that this setting is not saved and loaded correctly , but I`m busy in these days . That`s why don`t make any post about this ...like i say cosmetic bug . You might fix this easy i guess .
Latest betas are going high and high ... good work boys ( Hans , Bojcha ... and all the guys ... that reporting bugs ) . Keep it up and let`s make this software the best !
PostPosted: Sat Jun 25, 2011 11:46 am
in bandpass filter :
where in the processing is stage 2 ,4,6, and 8 ?
6 sounds best anyway
PostPosted: Sat Jun 25, 2011 2:14 pm
Bandpass filter order = how steep the slopes are. So you can set it higher if you need very steep slopes, or lower if you don't really care. Steeper slopes = more phase difference.
I've added saving the setting (apparently I forgot that in version 6.10?) to the todo list.
PostPosted: Sat Jun 25, 2011 2:41 pm
I did a test with the declipper.
I play a 500 Hz square wave from one pc through stand alone stereo tool.
With declipper on the output is going up en down like it's amplitude modulated.
Is it supposed to behave this way?
PostPosted: Sat Jun 25, 2011 2:44 pm
Does this only affect the order of the bandpass filter?
If I check the 2nd order filter which should only go down 12dB per octave it already looks extreemly steep.
PostPosted: Sat Jun 25, 2011 3:33 pm
And could you fix the bug that "lim output" in MB changes from 100% to 98% when i change "Final limiter" setting in the Limiting and Loudness window?
PostPosted: Sat Jun 25, 2011 5:05 pm
Hm, the answer to this is of course 'no'. I'll see if I can do anything about it (probably not for version 6.20). Did you discover this by accident or are there 'real world' situations where you get a similar behavior? (In other words: How bad is it? And do you hear it or only see it? Sorry, working on my laptop now and I don't have most of my software - including some to generate waveforms - with me)
Short explanation: Declipping is done on a windowed portion of audio. The sides are softer than the middle. And this can indeed lead to different reconstruction of clipping depending on where it occurs exactly. A solution would be to declip based on a wider region and ignore the sides, but that would increase (probably double) the CPU load and add some extra latency as well...
PostPosted: Sat Jun 25, 2011 5:06 pm
Ah, I hadn't noticed that one yet. Will add it to my todo list.
