Post new topic  This topic is locked, you cannot edit posts or make further replies.  [ 586 posts ]  Go to page Previous 17 8 9 10 1159 Next
PostPosted: Fri Jan 22, 2016 3:46 pm
7.85 BETA015
Windows stand alone: http://www.stereotool.com/download/ster ... 85-015.exe
Winamp DSP: http://www.stereotool.com/download/dsp_ ... 85-015.exe
Windows VST 32 bit: http://www.stereotool.com/download/vst_ ... 85-016.dll
CHANGED:
- Added option to switch between 1 and 160 bands for Exciter.
- Exciter generates more highs than the previous version (which generated too little). The amount of filtering is reduced though!
- Improved Exciter: Increased number of bands from 40 to 160. MP3-like artifacts AND distortion should be gone now.
- Exciter: Calculate target amplification levels for each bin using white (?) noise!
- Fixed some Exciter issues (which might have been the cause of errors that some people reported).
- Improved Exciter: Now using 40 bands instead of 1
- Added some filtering to make sound less 'sandy' (distorted).
- Exciter: Check why it sometimes boosts audio around 10 kHz (?) more than it should (Johnnie Cash) - protection filter appears not to work completely. Compare what happens without protection filter! -> Fixed (more or less)
- Added a soft of exciter (not an FM exciter but something that generates highs). I've placed it (for now) under True Bass, and it cannot be configured yet. Not really sure what to make of it yet, I think I like it but it does sound a bit "rough" sometimes. Note: It can cause pre- and post ringing at higher latency settings (I will fix that later, first want to get a bit of a feeling for what it does).
- Make scope skinnable
- "Bass AGC (Old)" panel
- "Classic Singleband" panel
- Try "True Bass" for highs -> Probably make a version where different modes (with/without filtering, with better HPF) are tested. Maybe also with multiple bands?? To reduce generated distortion.
- Exciter: Smooth curve to avoid ringing (which is now filtered out by later steps, but that's bad).
- Exciter: Add slider for Band Width
- Exciter: Add slider for Band Overlap
- Exciter: Add slider and checkbox (?) for Band Shape (half cosine, cosine, squared/square root)
- Exciter: Check why lowest part (just above start) is too soft.
- Add Polar stereo viewtopic.php?f=16&t=6233&p=33031#p33031
- O skin
- Show help in gui
- Blog post pre-processing
- Blog post MP3 and declipping
PostPosted: Fri Jan 22, 2016 7:31 pm
CHANGED:
Where did you add this setting? Unfortunately I only see the following settings. I am by the way, in the "Extreme Tweaker" mode.
The result is, incidentally, become much better!
PostPosted: Fri Jan 22, 2016 8:29 pm
Weird, it should be visible in that screen. Please check that it's really BETA015!
PostPosted: Fri Jan 22, 2016 8:39 pm
Ok I've checked. It is the beta version 15. The sound is also much better than in the other betas. In my user directory is also the appropriate settings file: "vst_stereo_tool_BETA785-015.ini".
PostPosted: Fri Jan 22, 2016 9:01 pm
Hallo Hans,
Deze versie klinkt goed.
Probleempje
Wanneer ik de Highs exciter aanzet dan loopt de input buffer leeg en gaat hij hakkelen.
1 band (off=160) werkt wel goed.
Groet,
audiostreamen
PostPosted: Fri Jan 22, 2016 10:57 pm
Ah, the VST version for 015 was never uploaded (what got uploaded was version 014, it says 'NOT YET AVAILABLE' next to the link!). So, you're getting the improvements of version 014, but not yet the option to switch to 1 band.
I'm re-uploading now.
PostPosted: Sat Jan 23, 2016 6:19 am
Awesome; I just found out, PNR works now as VST plugin in WaveLab. I can now select a tiny section in a WAV with the noise I want to be filtered out and by playing the selection in a loop and let Sterotool analyze it, I can pretty much finetune it.
BUT: WaveLab only takes the settings before I manually save them as preset. If I dont it seems it takes the last saved settings and not the current ones in the memory of the plugin.
BTW: I never switched from the "Classic Multiband" to the new one because I simply dont understand it. I am no sound engineer, so the classic one was understandable for me and it is easier to access, since I have everything on one page: I use it a lot when I remaster music tracks for my private collection and each music track needs different settings, and there I can tweak everything on one page easily. I also use the voice protection setting of the classic multiband a lot to control the volume of a singer in a music track. For newcomers and rookies the classic multiband is awesome, because you understand it without the need to know all the specifics. The new multiband looks like high mathematics too me, I have no clue what is happening there with all the knobs. If the new multiband would have a user interface which emulates the classic multiband it would make it more accessable for newcomers and easier to tweak the settings for individual tracks during remastering.
PostPosted: Sat Jan 23, 2016 10:29 am
Oh I'm sorry. I have just now read the sentence in the last beta. But thanks for the re-upload. Now the option also appears. The sound is still as good, if you take 160 bands. It's really hardly distorted, and principle useful. But a bit more configurations would be super.
PostPosted: Sat Jan 23, 2016 10:35 am
I've rendered it offline with the VST-Plugin, so I could have a listen anyway :lol:
http://www110.zippyshare.com/v/ItwQxaOR/file.html
First 1 Band, then 160 Bands and then Original. I've listened it through speakers and various headphones. 160 Bands sounds a tiny little less distorted, but there is IMHO not much of a difference. Overall, I always preferred the original. The Exciter always makes voices and noise-like sounds "scratchy", like played back on vinyl. I don't like this kind of sound much at all, sorry :oops: But all the vinyl-fans might be screaming at me right now :D
But it works pretty good on old records from the 50s and early 60s, which have few highs and scratchy sound anyway. On this kind of music, 160 Bands sounds clearly better, much less mp3-like artifacts.
PostPosted: Sat Jan 23, 2016 12:17 pm
Well what you can expect from sound that fully missing highs. I think this is awesome.
Also there is huge difference between 1 and 160 bands... huge!
