Post new topic  Reply to topic  [ 433 posts ]  Go to page Previous 17 8 9 10 1144 Next
PostPosted: Tue Sep 09, 2014 5:22 pm
Preset name does not show in the DSP version where it does in the standalone version.
PostPosted: Tue Sep 09, 2014 5:27 pm
It is showing as StereoTool 7.50 when I run the 51-014 beta dsp.
PostPosted: Tue Sep 09, 2014 5:36 pm
I notice that both Multiband and Classic multiband was enabled at the same time. By unchecking multiband, then "classic multiband" shows on left side. Clicking in to "classic mutliband", I see it is enabled. Is it normal to have both Classic and regular (newer?) multiband enabled at the same time? I don't know if this was a problem with my preset, or if some anomaly crept in recently.
PostPosted: Wed Sep 10, 2014 2:50 am
Preset loading Bojcha - Sevdah FM (Us, Stereo)
Exception in: GUI Event Handler (Exception 0xc0000005 at address 0x692d99, read/write=0, r/w location=0x0)
Restarting: NO
PostPosted: Sun Sep 14, 2014 4:34 am
@hvz: I have two suggestions for the MB
1- Move to place the "L. max Release" control to the section Speed ​​of MB, also is related to the section.
2- Limit the maximum peak of "Mix" to 12dB (20dB today) control for better accuracy in the values ​​due to more travel.
by GAP
"Less is More" (Bob Katz)
PostPosted: Sun Sep 14, 2014 5:10 am
It's related to limiter(s). So it's at good place.
PostPosted: Mon Sep 15, 2014 9:54 pm
I have no idea what the Bands setting under Advanced Clipper/Pre-limiter really does. I find it hard to believe there's even a remotely efficient 128 band crossover in existence, but maybe there is. In any case, why stop at 128 bands? I'm playing with 2048 right now. It doesn't appear to affect CPU much if at all, nor does it seem to affect the sound much. Maybe if I drove it harder.
Does anyone know what this setting does, or have any general guidelines for adjusting it?
PostPosted: Mon Sep 15, 2014 9:59 pm
I can tell you that i am using 32 and recommended is 128 or 256.
PostPosted: Mon Sep 15, 2014 10:02 pm
Can you actually hear the difference? Even with excessive drive to the clipper, I really can't hear anything change. How did you settle on 32?
PostPosted: Mon Sep 15, 2014 10:05 pm
One thing that might be problematic if you use more bands is that the response will be slower and it cannot detect transients. If you use 2048 bands for example, the only way of doing that is to look at pretty large blocks of audio. The smaller the number of bands, the more it will respond to short bursts. But also the bigger the frequency range gets that's affected, and at some point it may start to sound bad. I haven't had time yet to do more tests with this (although I heard from some people at the IBC today that they found that it works very well, especially on 1980's music if you use very slow compressor settings).
